moving to a SSD boot drive - clone suggestions?
picked up a nice size (90g Corsair) from Frys on sale this week with the idea of converting to SSD as my SageTV server boot drive.
anyone have suggestions on their favorite cloning software/procedures? My MB is limited to SATA II; 3gb bandwidth (the drive is SATA III - which I hope won't be a problem)
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
"Acronis Disk Director" from a boot CD. Make sure you set the boot partition to "Active" when you copy your boot drive. You should be fine with SataIII drive on SataII controller from everything I've read it should work fine - just don't have personal experience.
Make sure the alignment is correct when finished!!!
(VERY important for SSD's! If it was a new install on W7, it isn't an issue, but since you are cloning, make sure it is correct, after.)
Server #1= AMD A10-5800, 8G RAM, F2A85-M PRO, 12TB, HDHomerun Prime, HDHR, Colossus (Playback - HD-200) Server #2= AMD X2 3800+, 2G RAM, M2NPV-VM, 2TB, 3x HDHR OTA (Playback - HD-200) |
True Image would work but I don't remember if you can clone a partition without creating a backup file first. I use them for there original purpose. True Image for image backups of files/disks/partitions and Disk Director for resizing/partitioning/moving/copying.
Not trying to put extra work on you, but why not just reinstall fresh from the beginning? I realize it is a pain, but there is a big debate going on whether or not cloning from a non-ssd to an ssd is a good idea because of the differences in the way W7 installs, making sure TRIM is enabled and whatnot.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
In my case, I went from a 500GB HDD to a 128GB SSD. My HDD had two partitions (C and E), but were only using about 100GB between them. I used the Acronis Clone utility to clone the disk. Then I shut down and swapped the SATA cables between SSD and HDD and re-booted. At that point I was booting from the SSD and it had C and E, but the HDD was still there and Windows assigned different drive letters to the original C and E partitions. I deleted E from the SSD and re-sized the C partition to use the whole SSD. Finally, I went back and re-assigned the "E" label to my original E partition on the HDD. Since I was starting with Windows 7, I don't think alignment should be an issue. TRIM is another topic. My understanding is that for Windows to handle TRIM, you must have Windows 7 and your BIOS must be set to use AHCI mode for your boot disk. However, if you enable AHCI in your BIOS after you install Windows, your computer may not boot because it won't have the proper AHCI driver installed. There are many articles floating around that explain how to correct this by tweaking a registry setting. Otherwise, you have to be sure to set the BIOS correctly before installing Windows 7.
Server: Ryzen 2400G with integrated graphics, ASRock X470 Taichi Motherboard, HDMI output to Vizio 1080p LCD, Win10-64Bit (Professional), 16GB RAM Capture Devices (7 tuners): Colossus (x1), HDHR Prime (x2),USBUIRT (multi-zone) Source: Comcast/Xfinity X1 Cable Primary Client: Server Other Clients: (1) HD200, (1) HD300 Retired Equipment: MediaMVP, PVR150 (x2), PVR150MCE, HDHR, HVR-2250, HD-PVR |
But you are right that Win 7 does have a generic driver available that should work (As long as it gets enabled). When I get some time, I will check it out.
Maybe it was the lack of a proper AHCI driver. Maybe it was TRIM or alignment. But I copied my boot drive from a 500gb SATA to a 120gb Corsair SSD and used it for about a week. It was nice and fast, then one day I got a call that my wife and kids they couldn't watch TV. I tried to remote to the box, no go. When I go home that night I find the box at a BSOD, the drive had failed, had to revert to a backup and the 500gb drive. I then reformatted the SSD and was going to use it as RAM disk and then after about 2 days I come home to find the computer at the BIOS asking for f1 to proceed and the SSD is missing from the lineup. So my foray into SSD was a complete failure. I really want that speed, so I think I will RMA the drive and try again. But I will say that Acronis is the easiest way to go, I use it nightly for my incremental backups, but this next time around I think I will start from scratch and install everything and build it proper, just to make sure I get the SSD set right.
SERVER: Dual Core Xeon 3.0GHz 5160, 8gb RAM, Win7 x64, SageTV 9.0.13.536 w/ BMT, WebUI, OpenDCT, Java 1.70_79 TUNERS: 2 x Ceton PCIe InfinitiTV - FIOS STORAGE: UNRAID - 8tb for archived shows, DVDs, pictures and music CLIENTS: 2 x HD200s, 2 x HD300 |
I used Acronis. I can't remember how I did it. Either I used the "Clone Disk" feature, or I recovered an image of the old hard drive to the SSD on my general purpose computer.
I haven't upgraded the SageTV computer to a SSD yet. When the mechanical hard drive fails I will update to an SSD. You should be able to make the migration with Ghost too. You should own imaging software for your SageTV computer so you can image periodically. I take monthly full images and daily incremental images with Ghost 15. The images are stored on a secondary drive and automatically copied to an unRAID server. I can then easily recover to the previous day if a problem occurs. Dave |
If neither of those things work you may be looking at a complete reinstall or a drive replacement. Good luck.
To be honest the sandforce drives are awesome if you get a good one, but the most reliable drives as of now are Samsung and Crucial. Intel is too, but you pay too much for not that much better of a drive. Having said all that, Intel has a sandforce based drive, but they built their own firmware so it is more reliable that the other drives.
thanks for all the suggestions. I have now tried four different back-up / clone packages (MS W7 imaging - Driveimage XML - True Image and EaseUS. None have produced a working clone on SSD. No matter what is tried, I always get a windows warning in recovery saying either the disc is too small, can't be found, has an error or doesn't exist. I can't remember the last time making a clone of my C partition was such a failure. Anyone else have trouble doing this?
You might also try Clonezilla. Clonezilla is freeware. I don't think I've tried Clonezilla with Windows. I used Clonezilla with Linux before. I could recover a SageTV Linux server in less than 10 minutes with Clonezilla. Another freeware imaging product I've used is PING, Partition Image is Not Ghost. I was able to take images of a number of Windows computers and recover the images. Make sure the total used space on the old mechanical hard drive is less than the available free space on the new SSD. None of my testing with Clonezilla and PING was with an SSD, only mechanical drives. I am pretty sure that I used either Acronis True Image 2011 or 2012 disk cloning, or an image to move from a mechanical drive to a SSD on my general purpose computer. I've recovered my general purpose computer's SSD with an image several times with images, and the recovery process work flawlessly with images. Recoveries will be more reliable if your images are stored on hard drives instead of DVDs. Sometimes recoveries with optical media will fail. Dave |
three are freeware, so that isn't the problem. there seems to be great confusion regarding size of partition vs size of drive. I have a 1TB HDD, but the boot partition is only 60G. My SSD is 90G. The people who have used MS built-in image with W7 claim that partition size is all that matters. My concern is one of a hardware issue, as I have tried everything possible regarding software; Dispart, naming, activating, etc etc. Internet info is spotty and hard to find, as most people clone whole drives as opposed to boot partitions. Then there is that 100mb hidden partition...
| Moving recording library to new drive? | ryanroat | SageTV Software | 2 | 04-08-2009 08:53 AM |
| NVIDIA Boot Agent loads after Sage freezes; doesn't see hard drive | popechild | Hardware Support | 8 | 08-24-2007 07:27 PM |
| ? About Moving Recordings to Another Drive | geogecko | SageTV Software | 14 | 12-05-2006 06:43 PM |
| Suggestions for DVD drive and external enclosure? | blade | Hardware Support | 1 | 08-11-2005 08:12 AM |
| Moving to a new box. Suggestions? | rrussell | Hardware Support | 26 | 09-14-2004 01:31 PM |
