| SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
Program guide and MVP
I still use a couple of MVP's. The latest 7.0.12 update has made the program guide near unusable with them. Is there a way to switch back to the old version? I am using the standard STV's. Have tried both V3, and V7. You cannot tell where you are in the guide anymore. I don't want to stop using them because they do a great job where I have them.
I was having the same problem. Here's what I did.
1) Setup -> Help -> View TV Categories .. Delete ALL categories (5 or 6). 2) Setup -> Plugins -> All available -> Themes -> install the MBdiamond theme 3) Here was thing that really helped.. on the MVP the yellow button at the bottom opens the options menu (I didn't know this).. then I changed the font and the amount of columns to my liking. I can actually use it now on my 18" from about 7' away. Hope that helps. BTW, I changed the columns and font for all of the menus.
Server: i3 530 dual 2.93Ghz, 6GB mem, 2x 3TB 7200 rpm sata drives, Windows 7 ultimate 64-bit,Sagetv7.1.8 Beta Clients: 3x Hauppauge MediaMVP, 1x HD200, 1X HD300. TV provider: Comcast Digital, Up to 8 recordings at one time. Ceton 4 tuner cable card. 2x Dual Tuner HDHomeRun's (SageDCT 1.4 Ceton 1.0.6.1 |
Well that works a lot better. Not as good as it used to be but at least the guide is pretty much usable again.
The good old MVP lives to watch another show!! |
Thanks.....
Just wanted to state that I was disappointed in the MVP performance with version 7.
Your Post was a huge help.....MVP lives again..... MVP Sluggish problems no more.... ![]() ![]()
I submitted a Bug report and this was the answer. It works perfectly..
"Thanks, this'll be fixed for the next build. For now you can set: ui/allow_transparency_disabling_for_non_layered_clients=false in your Sage.properties file to resolve the issue." |
| Program Guide is gone! | freewheeling | SageTV Software | 3 | 07-15-2010 10:56 PM |
| STV Import: Alternative Program Guide & Mini Guide for Default STV | wado1971 | SageTV Customizations | 24 | 09-13-2009 01:32 PM |
| Program Guide doesn't look right in v6.2.5 | bcjenkins | SageTV Beta Test Software | 6 | 08-03-2007 07:02 AM |
| How to disable the popup window in the program guide? How to keep the program guide? | metropole | SageTV Software | 8 | 05-18-2006 06:25 PM |
