| SageTV Media Extender Discussion related to any SageTV Media Extender used directly by SageTV. Questions, issues, problems, suggestions, etc. relating to a SageTV supported media extender should be posted here. Use the SageTV HD Theater - Media Player forum for issues related to using an HD Theater while not connected to a SageTV server. |
I recently updated to version 7 on my WHS - everything went suprisingly smooth. I then began to update each of the three HD200s - again smooth. Added the SageMyMovies plug-in and I cannot reconnect to my server - it just freezes when trying to connect. I can get into the stand-alone mode. I have tried to reset the settings to the factory defaults several times, although after each reset - the most up to date update is still installed. When I try to connect to the server, it locks up again. This is only happening with one HD200 box, the other two connect to the server fine.
Is there any way to force an update on the HD200? I have reviewed the USB procedure which gives you a file to download. Everytime I try to download the .ver file, a new window appears with a string of numbers. I have successfully downloaded the .bin file and attempted the server method without success. Any suggestions?
System Specs WHS - Athlon 64 X2 4850e, Corsair 2GB DDR2 800 memory, 4.6 TB Western Digital Green Power (64k Clusters), Hauppauge HVR 1250, HVR 2250, and PVR 150 tuners for qam and analog, LG bluray drive, 3 HD 200s in extender mode on Gigabit Network; Sage Server v6.6.2.218, Java 1.6.0 |
there may be a problem with the client.properties file for that particular extender. it will reside in the Program Files\SageTV\SageTV\Clients, and be named [EXTENDER MAC ADDRESS].properties. You might try either removing, or renaming that .properties file, and see if it works. (removing or renaming it will cause it to start a fresh one, based on the server's 'default' proeprties).
Before I noticed your post, I was playing around a bit.
I used one of the working HD200s to examine the installed plugins and sure enough the SageMyMovies UI had an indicator that showed it failed. I then proceeded to uninstall all associated plug-ins for SageMyMovies with a restart after every uninstall. Everything went smoothly. I started the HD200 box which was previously freezing at the server connection screen. To my relief, the problem was resolved and I was back into the extender menu ![]() Thanks for your reply, if I ever run into that issue again - I will give it a try.
| HD-200 Frozen after Firmware Update - Factory Reset fails | Spriter | SageTV HD Theater - Media Player | 12 | 09-12-2010 03:22 AM |
| Frozen playback | BrettS | SageTV Software | 0 | 12-26-2009 06:00 PM |
| Mouse frozen whenever SageTV is opened | shimrod | SageTV Software | 0 | 11-18-2009 04:56 AM |
| Frozen Picture or Audio out of Sync when FF or RW | graywolf | SageTV Software | 0 | 11-09-2009 05:45 PM |
| HELP: No Sound & frozen Video | joh3004 | SageTV Software | 0 | 08-12-2005 02:47 PM |
