SageMC Custom Interface This forum is for discussing the user-created SageMC custom interface for SageTV. |
IMDB does not work
I have been using sagemc for some time. I have just started to use imdb, but when I try i get an error msg like the one in the attachment.
Can someone help me with this? |
I am guessing you are not using the latest version of sagemc this was a problem in older versions.
Thanks for the reply.
I have sagetv 6.6.2 and have just loaded the sagemc 6.3.9.b.23. The same problem still exists |
its due to an outdated imdb parser file... to fix all you have to do is update the parsing files with the new ones...
they can be found here NEWEST IMDB SEARCH you dont have to import it because its already in the sagemc .xml file |
Thank you skippyd77. that seems to have worked. much obliged for your help.
imdb | Hans | SageTV Customizations | 0 | 07-10-2009 11:41 AM |
Imdb Search | sbherculano | SageMC Custom Interface | 0 | 08-09-2008 02:13 PM |
Need help getting IMDB to work on Linux install | bfgarcia | SageTV Customizations | 3 | 02-25-2007 01:34 PM |
IMDb Import ? | Polypro | SageTV Customizations | 2 | 11-12-2005 03:37 AM |
IMDB Stuff | Alig Proudblade | SageTV Customizations | 5 | 05-17-2005 02:36 PM |
