SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
Aspect Ratio on HD-100, using HD-PVR Recordings, on 4x3 HD TV
Hi folks,
Got my HD-PVR up and running this week (yay) and am having some Aspect Ratio issues. First, let me say that I've read this FAQ (and other posts): http://forums.sagetv.com/forums/show...712#post252712 ...and have not found an AR that works for me. I currently have the following AR's in place, taken from default settings and various posts on these forums: Source Fill ZoomA ZoomB Letterbox Panoramic 4x3Stretch Taller Now, on my widescreen monitor in the other room, everything works fine. However, on my 4x3 HD tube TV...I can't get SD content to widen (picture is too skinny) and none of the settings seem to be working. How can I go about fixing this? As much as I'm enjoying my HD-PVR, a good majority of content recorded is SD and this is driving me a bit nuts. Thanks for any help!
Al Bsharah / Twitter Clients: Two STX-HD100 High-Def Extenders Media Server / NAS: Case: Thermaltake Armor CPU: AMD Opteron 1218 (2.6GHz Dual Core) Motherboard: ASUS MN2-LR Memory: 2GB Gfx Card: Headless Tuner: Hauppauge HD-PVR, Hauppauge PVR-350 (not in use) O/S: Windows 7 Sage: Latest RAID: On-Board Drives: 6 x 1.5TB SATA RAID-5, 2 x 80GB IDE RAID-1 (O/S) Storage: 7.5TB Total |
Thanks for the link. I've tried all kinds of settings and I simply can't get the image to stretch any width-wise. Granted, I'm really new to the AR settings and they're confusing as hell...but I've tried things like:
ALStretch|source\=2048,2048,3496,3496|cutstrip\=2048,0|blackstrip\=0,0|nonlinearmode\=0,0; ALStretch|source\=2048,2048,2048,2048|cutstrip\=2048,0|blackstrip\=0,0|nonlinearmode\=0,0; ALStretch|source\=2048,2048,2048,2048,FrontEdgeToCenter,FrontEdgeToCenter,Fixed,Relative,Fixed,Relative|cutstrip\=2048,0|blackstrip\=0,0|nonlinearmode\=0,0; ALStretch|source\=2048,2048,3496,3496|nonlinearmode\=0,0; ALStretch|source\=2048,2048,2048,2048|nonlinearmode\=0,0; Grr, argh. This is very unintuitive and quite annoying. Thanks for the help thus far...any other ideas?
Try nonlinearmode=0,1 and then mess with all the other settings (you are using the default STV with the latest beta right - so you can see the changes as they happen??????)
btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
This is one that I use :
Anamorphic|blackstrip\=0,0 |cutstrip\=0,0 |nonlinearmode\=0,1 |scalingmode\=LetterBox |source\=2048,2048,4096,3196, FrontEdgeToCenter,FrontEdgeToCenter, Relative,Relative,Relative,Relative; If you change the source line to 2048,2048,3000,4096 that might work - should start expanding in the X axis instead of the Y (which is what the above "Anamorphic" setting does....) Of course 3000 is a guess, you'll have to play with it some. btl.
I just ordered an HD Extender for the SD TV in the family room and will be doing this next week when I receive it. If all I am outputting is 720p, is there a setup I should use, and does the default stick? I only use this tuner to record HD channels as I didn't want something SD to take precedence over HD.
TIA B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
I think the X and Y axis issue might be circumvented if you set nonlinear=0,1 - it surely is doing that on my HD100's. I only touch the Y axis and it adjusts very nicely.... btl.
I tried that and it wasn't working for me but I may have had other things set that made it not work. Also I wasn't trying to do a nonliner stretch it to fill the screen. I wanted to keep the original AR since it fit a 16x9 display approximately anyway (Letterboxed SD). But if the stretch works and doesn't look bad on a 16x9 letterboxed SD on the HD-PVR I will use it. Have to experiment some more this weekend with it if I get some recording windows. Been using my nVidia Dual TV tuners for SD because of this since THEY stretch just fine on the HD-100.
Solution!
Ok, I've got a solution! This is the one I used (my values):
SDon4x3HDTube|blackstrip\=0,0|cutstrip\=0,0|nonlinearmode\=0,1|scalingmode\=LetterBox|source\=2048,2048,3500,4096,FrontEdgeToCenter,FrontEdgeToCenter,Relative,Relative,Relative,Relative; Other questions / answers * I am running Beta 6.4.3 (not Beta 6.4.4). In 6.4.4, is there an OSD section for AR? Or, does the system just catch changes to the config file on-the-fly? * My cable box outputs 480i and 1080i, depending on the channel. I have not fixed it to send all 1080i. * Is there a way to set a default AR? Obviously, this doesn't work for HD content...and I have a lot of both, but I think more SD than HD now. Sucks that it doesn't remember the last AR chosen when watching a different show. Would actually be really nice if you could set an AR to 480i recordings, and another AR to 1080i recordings (so it would adjust automatically). Thanks guys!
BobP. Last edited by BobPhoenix; 06-20-2008 at 10:58 AM. Reason: Added qualification |
You're best bet is the auto aspect ratio switcher plugin - there's one that works in the default STV, and then one that works in SageMC. The SageMC one is buried somewhere in one of the SageMC threads - not in the download section!
It gives you the most control over aspect ratios. However, the HD100 also has an option to set a global default aspect ratio. It has never really worked for me though - more often than not if I try to let that property manage the default I end up with Source. YMMV. In the 6.4.4 beta you can select this property in the same popup screen that BobP. is talking about above. btl.
Thanks again for all the help, guys! I'll try and poke around a bit for the Auto AR Plugin for SageMC.
Aspect Ratio, again. (beta 6.3.1) | Patilan | SageTV Beta Test Software | 15 | 11-28-2007 03:16 PM |
HD Aspect Ratio Newbie | MattJackson86 | SageTV Software | 1 | 08-14-2007 10:30 PM |
Another aspect ratio question! | maninblack_30 | SageTV Media Extender | 6 | 10-19-2006 09:49 PM |
AUUUGH I Give UP!!! | TripleTapper | SageTV Media Extender | 46 | 01-03-2006 02:35 PM |
PVR 500 MCE Rebooting PC | jptaz | Hardware Support | 30 | 01-07-2005 01:44 PM |
