| SageTV Customizations This forums is for discussing and sharing user-created modifications for the SageTV application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss customizations for SageTV version 6 and earlier, or for the SageTV3 UI. |
|  | Thread Tools | Search this Thread | Display Modes |
|  Utility: Linux/OS X batch beta firmware upgrade script
			Greetings, Please note: I cannot take responsibility for use of these scripts, but it works for me. USE AT YOUR OWN RISK I only have 2 HD Extenders now, but will be adding 5 more to the mix by the time I am done. Firmware upgrading multiple devices would be painful sitting in front of each TV. I am attaching 2 scripts telnet_extender.sh: Quote:
 Code: ./telnet_extender.sh | telnet ip_address_of_extender Code: chmod +x telnet_extender.sh
				__________________ Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT Last edited by bcjenkins; 08-09-2008 at 12:53 PM. |
			Used the script to update 2 extenders easily. To determine IP addresses of your extenders try nmap (as root) and look for (Shanghai DareGlobal Technologies  Co.) Otherwise, I would reserve in DHCP the IP addresses. B
				__________________ Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
			bcjenkins, Nice work! I have no idea how you figured this out. Does it update the firmware faster than doing it through the UI? Mine takes about 20 minutes. Personally I don't think I'll use the script. I like what you've done and I'm interested in how the HDX works, but am reluctant to do anything unsupported to it. It's low-maintenance and I want to keep it that way  I'd like to know what else can be done with HDX, though. Please update us on anything you find.
				__________________ Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun. Extender: STP-HD300, Harmony 550 Remote, Netgear MCA1001 Ethernet over Coax. SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client, Java 1.6. Plugins: Jetty, Nielm's Web Server, Mobile Web Interface. |
			It updates faster for me because I don't have to go to each TV and type in all the codes, etc. You can also adjust settings from the terminal prompt as well. This means some enterprising soul could actually work a settings adjustment into the web server add-on. To adjust the settings, I telnet in and
 B Quote:
|  Similar Threads | ||||
| Why are we in beta hell here? | Bohica | General Discussion | 76 | 02-19-2006 10:43 AM |
| Beta upgrade broke MultiDCT | polarhyte | SageTV Beta Test Software | 1 | 10-30-2005 06:56 PM |
