SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
Transcoding of DTS audio on HD Extenders!?
Am I the only one who noticed that the long awaited transcoding of DTS audio to 2-channel stereo "may" finally be ready?
![]() In the 6.4.5 release notes there is this: 3. Added property 'miniclient/disabled_audio_codecs' which allows disabling of specific audio codecs for an extender/placeshifter which will then require the server to transcode that format (i.e. you want to disable DTS pass-through) I added miniclient/disabled_audio_codecs=DTS;DCA;dts in my HD extender's {mac address}.properties file. The result is that both video and audio are transcoded rather than just the audio part. The video part is of bad quality ~ VCD level. My .properties file also had these lines in it miniclient/conservative_transcode_mode=SVCD miniclient/conservative_transcode_mode_6ch=SVCD6Ch could they have something to do with this? Does anyone have clues on the exact use of this property? NARFLEX or Andy care to enlighten us? ![]()
Windows 10 64bit - Server: C2D, 6Gb RAM, 1xSamsung 840 Pro 128Gb, Seagate Archive HD 8TB - 2 x WD Green 1TB HDs for Recordings, PVR-USB2,Cinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2 3 x HD300s |
Getting the exact same problem here, used to be able to view 720P and 1080P mkv's no problem but with no sound as DTS and connected via HDMI to my TV (and chose HDMI audio output).
Put in this property as you in the HD100's client .properties and the video also gets transcoded very badly but I do get audio ![]() Support advised me in an earlier ticket when I requested DTS transcoding that you would need to put this property into sage.properties file in the main folder, but that doesn't seem right to me and I couldn't get that to work. |
You may want to try putting it in the sage.properties on your server and take it out of the HD client's property file. There are settings for all the miniclients that go on the server. Make sure you quit Sage (not sleep) and/or stop the service before you edit it. With it being put in the client properties might be why it is affecting the video also.
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. |
If this property goes in the server's .properties then it affects all clients.
This may not be desirable since for some clients I do have a dts capable receiver.
Because of the firmware update it may only pertain to the HD Extender. You may as well try it and confirm if it does or doesn't work.
I have tried in the server as well but the property there has no effect. The video comes out OK but no sound through HDMI.
So it looks like it should go in the extender's .properties file. I am filing a support request.
I got a reply from support.
This is the option to do DTS transcoding. The entry should go in {mac address}.properties file of the particular extender. Apparently, the Video also has to be transcoded otherwise there are syncronisation issues. Support suggested to change Extender Conversion quality to High. I am not sure what resolution the Video will be transcoded to. If it is similar to my MVP experience then I am sure my server doesn't have enough horsepower to do it....... ![]()
Bad news then, I'm same boat as you and my server certainly does not have enough power to decode video for 720P or 1080P mkv's.
Guess I may need to look at converting all my HD mkvs from DTS to AC3 ![]() |
What is the correct setting for the best quality, I will try it on my gear, I do not know if my Sage server's dual core will cut it, but I could at some point try it on a quad.....
Rackmount 20 drive hotswap case, 2x Intel e5410 Xeons, 4GB FBDIMM, 1x 80GB (OS), 14x 1TB in raid 5(DATA!!), Aerca 1280DML, Server 2k3 Enterprise x64 R2. Sage 6.4.8 |
Just tried the popcornhour converter and that seems like an easy way of converting my mkvs from DTS to AC3, look here:-
http://www.digital-digest.com/softwa...Converter.html |
Server: AMD Phenom 2 920 2.8ghz Quad, 16gb Ram, 4tb Storage, 1xHVR-2250, 1 Ceton Cable Card adapter, Windows 7 SP1 |
on movies with DCA audio encoding i gets black screen and no audio.
with DTS everything work fine. I put into this line DTS;DCA;dts;dca any advice?
Dear Google, Please don't ruin SageTV for us!! Sage Server: [s]8xDVB-S2 with DVBE4Sage on YES DBS Israel 4W (3 virtual tuners) ,[/s] 3 x HD300 Extenders; 3 x HD200 Extender; 3 x SageTV Client; |
Audio Dropouts on HD extender | dwk | SageTV Media Extender | 1 | 04-10-2008 08:39 AM |
How do I play AC3 DTS audio | qhplar | SageTV Software | 1 | 02-29-2008 12:38 PM |
SageTV V6.3.10 Release Candidate | Narflex | SageTV Beta Test Software | 0 | 02-28-2008 06:07 PM |
HD extender audio out question | Octathorpe | SageTV Media Extender | 5 | 12-10-2007 09:06 AM |
HD Audio with placeshifter | OttoNP | SageTV Placeshifter | 0 | 04-18-2007 11:48 AM |
