SageTV Media Extender Discussion related to any SageTV Media Extender used directly by SageTV. Questions, issues, problems, suggestions, etc. relating to a SageTV supported media extender should be posted here. Use the SageTV HD Theater - Media Player forum for issues related to using an HD Theater while not connected to a SageTV server. |
I purchased 28" LCD monitor with HDMI audio HANNS HG281DPB from http://www.hannsg.com/us/
I did setup monitor to have HDMI Audio source and HD extender have HDMI audio output but nothing heared.... any advice? ![]()
Dear Google, Please don't ruin SageTV for us!! Sage Server: [s]8xDVB-S2 with DVBE4Sage on YES DBS Israel 4W (3 virtual tuners) ,[/s] 3 x HD300 Extenders; 3 x HD200 Extender; 3 x SageTV Client; |
Are you sure this can do audio in via HDMI? I don't own it, but I didn't see anything in the manual stating this could actually be accomplished. I didn't spend a lot of time looking so I may have missed it.
Sage Server: AMD Athlon II 630, Asrock 785G motherboard, 3GB of RAM, 500GB OS HD in RAID 1 and 2 - 750GB Recording Drives, HDHomerun, Avermedia HD Duet & 2-HDPVRs, and 9.0TB storage in RAID 5 via Dell Perc 5i for DVD storage Source: Clear QAM and OTA for locals, 2-DishNetwork VIP211's Clients: 2 Sage HD300's, 2 Sage HD200's, 2 Sage HD100's, 1 MediaMVP, and 1 Placeshifter |
![]() Quote:
See if setting the audio on the extender to S/PDIF will make your HDMI audio work.
![]() Quote:
also i have a problem when I press Power button on remote control, Sage HD Extender is start sleep(disappears picture from the screen) but Monitor still powered (blue light is on). only when I switch power on/off button on rare panel of Sage HD Extender then only Monitor is go to sleep (yellow light is on) - please advice.
Dear Google, Please don't ruin SageTV for us!! Sage Server: [s]8xDVB-S2 with DVBE4Sage on YES DBS Israel 4W (3 virtual tuners) ,[/s] 3 x HD300 Extenders; 3 x HD200 Extender; 3 x SageTV Client; Last edited by bjkiller; 03-09-2008 at 11:56 PM. |
The only way you can verify all of this is to use another HDMI device, but I have a feeling you will get the same results.
![]() Quote:
The monitor has built in speakers that can be driven either by HDMI (if you hookup a DVD player for instance) or via a separate audio input. The monitor also has audio out, so you can connect better speakers (the built-in ones face backwards as they are on the backside of the monitor, so they have poor projection). They are ok for casual movie watching though. in 2 days i will get SAT BOX with HDMI output so i will able to test audio of the monitor.
You will have to let us know how that works out. It appears that what you are quoting there is the same person who has posted it through out the net on various review forums, but never actually states s/he is using it this way.
![]() Quote:
Well at least it works for your cable box!
Mine worke out of the box hooked via HDMI. As long as the audio setting on the HD100 is set to either SPDIF or HDMI, you should get audio out of it. For what you want, it probably should be on HDMI (since I THINK that only passes 2 audio channels).....
I should mention that the only one I have hooked via HDMI is hooked into an Onkyo TX-SR605 (where it acts as a switch) and then on to my Big screen so I haven't tried HDMI directly to a tv...
![]() Quote:
Are you using the lastest HD100 firmware? There were some HDMI issues fixed between firmware revisions.
[size=1]-MrD ============= Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients Intel Xeon L? 32Gb CetonTV cable card /FIOS |
I just read the manual
http://america.hannsg.net/filectrl/HG281_UM_EN.pdf I never got the impression digital audio was supported? All connection diagrams use an analog cable. This unit will definitely not decode DTS streams.
![]() Quote:
Somebody can advice how to test with LPCM and AC3 streams via HDMI audio?
When I play Mp3 files witch stream go out LPCM?
it's fixed with latest beta of HD Extender firmware...
now waiting to server DTS decoder....
http://forums.sagetv.com/forums/showthread.php?t=33111
I was unable to get HDMI or Stereo working on the extender - even running the latest beta. The fact you were able to tells me to send it back. Cheers Mark
Luckily Computers Repair Themselves |
SageTV V6.3.10 Release Candidate | Narflex | SageTV Beta Test Software | 0 | 02-28-2008 06:07 PM |
STX-HD100 and HDMI is a NO GO!!! | Stuntman | SageTV Media Extender | 11 | 01-25-2008 01:12 PM |
HD Extender starts playback in wrong place | iammike | SageTV Media Extender | 10 | 01-24-2008 08:10 AM |
Need some help with a few questions...and I love the new HD extender | garyellis | SageTV Media Extender | 1 | 12-19-2007 03:37 PM |
Audio level on HD Extender? | KJake | SageTV Media Extender | 6 | 12-15-2007 11:49 AM |
