Old 12-16-2007, 02:38 PM
Glass Glass is offline
HD Extender and USB Wireless N Adapter?
Would the new HD Extender work with this Wireless N adapter?
http://accessories.us.dell.com/sna/p...682&lid=585553
Old 12-16-2007, 02:41 PM
fyodor fyodor is offline
It can't accept a usb adapter. You will need some sort of ethernet to wireless bridge.
Old 12-17-2007, 02:02 AM
Thanks!
Bummer, though. Hope Sage comes up with a wireless N box, for those of us who don't have the option of running CAT cables.
Old 12-17-2007, 11:51 AM
emok emok is offline
Not sure how your experience has been with 11n, but mine hasn't been so great. I'm using a Netgear WNR854T with the WN121T (usb) and the performance has been inconsistent (though I did have better luck with the PCI card). Stuttering with HD content has been inconsistent. I've even had stuttering with SD content sometimes and every time I check, I'm still connected at "300Mbps" (which I believe actual max throughput is closer to 25-30Mbps). The main issue is inconsistency, sometimes the show will stutter, sometimes the exact same show won't.
Perhaps other brands are better or maybe you should want for 11n Draft 2.0 products to hit mainstream (they're staring to trickle in) and try those out.
Old 12-17-2007, 09:29 PM
flavius flavius is offline
Have you tried different channels?
Old 12-18-2007, 02:10 AM
Yup, I think I've tried every channel. And the network density around here is pretty low, too. I tried running only N clients as well. No luck. It's just very inconsistent for me.
Old 12-18-2007, 03:51 PM
sandor's Avatar
sandor sandor is offline
i run ATSC (OTA HD) via 802.11 n with no problems. i routinely run one client and one placeshifter (LAN setting, ie no compression) without a single hitch. i have tested,briefly, 3 wireless clients with no problem from anywhere in my 1100 sq ft bi-level apartment. all metal studs, so not the most radiowave-friendly locale.
i use a DLink DIR 655 "N" router with a pair of macbook's as clients. I can sustain about 5-7x the transfer rate that my old WRT54G used to peak at.
MacBook Core2Duo 2 ghz
nVidia 9400M GPU
46" Sammy HLP4663 720p DLP
2x HDHR, all OTA
QNAP TS-809:
12.5 TB for Recordings/Imports/TimeMachine/Music
HD200 via 802.11n in Living Room
802.11n client in bedroom
Old 12-18-2007, 05:27 PM
mikesm mikesm is offline
The DIR-655 is a very nice router. The new 855 is supposed to be out soon, and it does N on both the 2.4 and 5 Ghz bands, which is nice since the Intel notebook N hardware likes to run at 5 Ghz...
But if you are look for an N wireless access point/router, the DIR-655 seems to be the way to go now.
Server: Sage 6.5.9 - X2 3800+, DFI NF4 MB, 1 GB, 300 GB HD (system disk), NV 7600GS, - Windows XP SP2
Client 1: Sage 6.5.9 - E7200, Abit IP35 Pro, ATI 4850 with HDMI connect to Denon 3808CI and Sony A3000 SXRD TV
Client 2: HD200 connected to Denon 3808CI and A3000 SXRD TV
Client 3: Media MVP to 15" Toshiba LCD
Client 4: HD100 connected to Samsung 23" 720P LCD
Client 5: HD100 connected to Vizio VX37L
Old 12-19-2007, 10:13 PM
What I don't like about the latest D-Link routers is that they started to turn off bridge mode in some of their routers.
I just got an Airport Extreme which I run in bridge mode. No problems with HD playback on my N-equipped Mac's.
SageTV Media Extender FAQ Opus4 SageTV Media Extender 20 09-13-2010 09:13 PM
Run Placeshifter from USB Drive? David81 SageTV Placeshifter 25 09-13-2009 04:04 AM
HD media extender USB ports covers bastafidli SageTV Media Extender 4 12-13-2007 02:47 PM
My Home Network Setup - Think this will work? geogecko Hardware Support 3 12-06-2007 07:58 PM
