Go Back   SageTV Community > SageTV BETA Release Products > SageTV Beta Test Software
SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here.
Old 02-16-2007, 09:16 PM
lovingHDTV's Avatar
lovingHDTV lovingHDTV is offline
6.1.3 broke my remote
I installed and ran 6.1.3 on both my server and client. However, on my client every push of a up, down, left, or right button it moves twice.
I can run my 6.0 client.exe and it works, 6.1.3 client does not work.
I submitted a bug, and uninstalled 6.1.3 as it is unusable when the remote does not work.
I use a Harmony 880 with a USB-UIRT.
To uninstall all I did was rename the 6.1.3 directory and rename my original back to SageTV and run. So I'm fairly confident that it is SageTV that is broken.
Old 02-17-2007, 05:33 AM
blade blade is offline
Look in your properties file and find:
infrared_receive_repeat_delay=
infrared_receive_repeat_delay_new=
infrared_receive_repeat_period=
infrared_receive_repeat_period_new=
Increase the new ones to the same value as the old ones. At least that fixed the problem for me.
Old 02-17-2007, 10:14 AM
lovingHDTV's Avatar
Blade,
Thanks that fixed it for me also. My "old" delay was 250 the "new" one was 30.
I'm running fine now.
Old 02-17-2007, 01:37 PM
BTW: I'm not sure which install method was used here, but if you install over the top of the previous version, it should keep your current settings. If you do a completely new installation to a blank directory, everything will get reset to the defaults.
Old 02-17-2007, 02:36 PM
lovingHDTV's Avatar
Well I it should it didn't. I installed over the top of my 6.0 install and it broke things. I then tried installing in a clean directory and it was broken also.
Old 02-17-2007, 03:59 PM
I also installed over an existing install and it used the new values instead of the old ones.
Old 02-17-2007, 04:25 PM
If an upgrade resets existing properties when installing on top of an old version, I would file a bug report. There may be a few properties that need to get changed for some installs, but I don't think these are any of them.
Old 02-17-2007, 05:06 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Andy,
This was done by design. The property value names were changed so they would become the new default. This helps significantly with remote response on the MVP (combined with some other changes).
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-17-2007, 05:48 PM
lovingHDTV's Avatar
Well it may work for an MVP but it broke me and I'm sure others as well. I did get it working again by using my old numbers.
Old 02-17-2007, 05:50 PM
Oops.... never mind. I obviously missed the 'new' names on the properties, even though the above posts mentioned new & old.
Old 02-18-2007, 01:36 PM
Halstead Halstead is offline
Originally Posted by Narflex
Andy,
I had the same problem. I think this is going to annoy a huge number of users when they upgrade. may I recommend some UI element in the new installer that lets uses choose the old or new settings?
Halstead York
HTPC/Server: A8 3850; Win 7 Home x86 + Java 1.6.0_26; Sage 7.1.9; Driving Epson 8500 pj @ 1080p | Office: Core2Duo E8500 w/ EFI-X running OS X 10.5 & Win 7 Pro x64 (dual boot) + Java 1.6.0_20; Sage 7.0.23; Driving 30" Samsung 1900x1200 monitor
Old 02-18-2007, 01:45 PM
Wheemer's Avatar
Wheemer Wheemer is offline
seems like the "design" may need to be reworked then...
Old 02-18-2007, 02:29 PM
Narflex's Avatar
Sage
OK, we'll change this so it only applies to media extenders so it doesn't effect everyone else.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-18-2007, 02:33 PM
Thanks. These forums always remind me of why I'm a loyal SageTV user.
Halstead York
MCE Remote not work fully with Placeshifter devinteske SageTV Placeshifter 5 02-08-2007 11:45 PM
Already broke Streamzap remote. traker1001 Hardware Support 6 12-26-2006 10:51 AM
How to get SageTV to release focus to NVDVD for remote IncredibleHat SageTV Software 4 07-06-2006 07:47 AM
Do i have my remote control options understood orangezero Hardware Support 6 05-05-2006 10:32 PM
Bought new Hauppauge remote, now having problems supernoob Hardware Support 1 02-26-2006 01:10 PM
