Go Back   SageTV Community > SageTV BETA Release Products > SageTV Beta Test Software
SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here.
Old 02-28-2006, 02:11 PM
RAlfieri RAlfieri is offline
Not Connecting When Running as Service?
I setup the 4.18 beta on both the server and client. I was able to connect with placeshifter when NOT running the server as a service.
I switched to a service and now it is not responding. I'm getting Java connect timeout errors.
Any ideas?
Thanks,
Rob
Rob Alfieri
IT Consultant
HP Media Center m390n, P4 2.4GHz, NVidia GeForce 5600 FX, Hauppauge PVR-250 PCI II, NVIDIA PureVideo Decoder, Microsoft Windows Media Center PC 2005, 1GB RAM, (2) 600MB HD, Motorola DCT5000 STB, USB-UIRT, Time-Warner Digital Cable
Old 02-28-2006, 03:18 PM
It sounds like perhaps sagetv.exe is allowed through your firewall, but SageTVService.exe isn't.
Old 02-28-2006, 06:19 PM
Thanks, Andy. I'll add that executable to the media center system firewall. Any other apps or ports I should check?
Rob Alfieri
IT Consultant
Old 02-28-2006, 06:38 PM
Adding Service Worked, Had to Tweak Streaming Setting
I added the app to the media server firewall settings and it worked. The next issue I had was in streaming out over the Internet using the default Dynamic settings. The video would not start.
I changed the settings to use the default manual settings and the stream started immediately and worked beautifully.
Thanks,
Rob
Rob Alfieri
IT Consultant
