| SageTV Github Development Discussion related to SageTV Open Source Development. Use this forum for development topics about the Open Source versions of SageTV, hosted on Github. |
|  | Thread Tools | Search this Thread | Display Modes |
			#81
| Quote:
			#82
			That is interesting.  I am not sure if that is a SageTVTranscoder thing or not.  What device are you playing back the AVI on?  Does SageTV properly detect the duration of the file?
				__________________ Projects I am currently maintaining SageTV Andoid Client Media Format Parser Plugin JavaFFmpegLibrary SageTVTranscoder If you like the work I am doing and would like to support it you can become a Patreon member. |
			#83
			It's happening on both Windows clients and Android clients and I believe it started around the time of an update to the server that allowed it to correctly detect HEVC files. Timeline shows the video as 0 length. I do recall that there was an option used when the HEVC detection came out to tell sage to re-detect all videos (maybe I need to do that again?) |
			#84
| Quote:
 I would be willing to attempt to figure out what is going on. I might be able to at a minimum provide some insight. Thanks, Josh
			#85
			I am super close to posting a beta for the new SageTVTranscoder.  I am just working on automating as much of the build and publish as possible as part of the first release.  I am hoping to have something out this weekend if things go as planned. Josh
			#86
|  Beta SageTVTranscoder Plugin released
			Hi All, I have released the SageTVTranscoder Plugin to the repository. This is available for use. This is currently only available for Windows x64 bit systems. You can use it on both x32/x64 SageTV installs. We should be able to compile this for linux without much issue. Question: Where do you guys think I should post this on the forums? This should work for most version of SageTV. Should I make a new post under GitHub development? Should I place it under one of the Customization sub forums? Why should I care about this?: Good question. I will try and post some of the reasons this plugin is important.
			#87
| Quote:
				__________________ Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
			#88
| Quote:
 This SageTVTranscoder.exe is compiled as a 64bit executable. It will only run on a 64bit windows OS. I am going to expand with more builds over time. x32 and Linux.
			#89
| Quote:
 thanks
			#90
| Quote:
 MediaFormatParser Plugin and SageTVTranscoder Plugin
				__________________ SageTV running on: Win10 21H2 SageTV 9.2.6.976 (64 bit) Java 1.8.0 311 (64 bit) OpenDCT 0.5.32 (64 bit) Clients: HD300 (x2) HDHR3-CC Prime 20220822 (Comcast CableCard) - 3 Tuners HDFX-4K Flex 20220822 (OTA) - 4 Tuners |
			#91
| Quote:
  Josh
			#92
			Can you clarify when the transcoder is used?  Is this just used for the Linux client?  Is it used for other Miniclients like HD200 or HD300 extenders?  What about the full Windows install or the Windows client? Do they use the transcoder?
				__________________ New Server - Sage9 on unRAID 2xHD-PVR, HDHR for OTA Old Server - Sage7 on Win7Pro-i660CPU with 4.6TB, HD-PVR, HDHR OTA, HVR-1850 OTA Clients - 2xHD-300, 8xHD-200 Extenders, Client+2xPlaceshifter and a WHS which acts as a backup Sage server |
			#93
| Quote:
 This will be used for HD100,HD200,HD300,Placeshifter or AndroidClient when transcoding is required. This is usually when the codec is not support by the device. Or when there is a low bandwidth connection. If not using my Media Format detection plugin, this will be used to detect media files when the external format detector is called. This is used in the internal encoder to reencode recordings and library content. I do not know the name of this in the frontend. This is used to generate thumbnails for media files. Thanks, Josh
			#94
| Quote:
 With this, would be able to watch HEVC files on the HD200/HD300 because it will transcode it to a format they understand? What performance considerations would transcoding on the fly have? Skip FWD/RWD impact/delay? Sounds very interesting |
			#95
| Quote:
 Each users mileage will vary. Josh
			#96
| Quote:
 What is the 'repository'? It doesn't look like I can install it via Setup>Plugins, even though it's called a Plugin.
				__________________ Server: Intel i5-11400 @4.4GHz 6 cores Windows10 Pro, Sage 9.2.6.976, Comskip Donators Capture: Fubo/TVEverywhere/ChannelsDVR/OpenDCT_0.5.32_x86. Storage: 120gB SSD, 4tB HD on Server Network: gB Lan Playback: FireStick 4K miniclient Tech Level: Hobbyist |
			#97
| Quote:
 Josh
			#98
			Found and installed it!  Thanks, Josh. Hoping that it fixes the halts during the football game due the 6Mbs DSL service from my ISP.
			#99
| Quote:
 It sounds like your problem is getting a stable feed INTO your LAN over the WAN due to your slow internet speed. This plugin can't help that because it takes a file that is already on your LAN and transcodes it to send somewhere else. If you are having trouble getting a stable feed onto the LAN, that occurs before this plugin can do anything about it.
				__________________ i7-6700 server with about 10tb of space currently SageTV v9 (64bit) Ceton InfiniTV ETH 6 cable card tuner (Spectrum cable) OpenDCT HD-300 HD Extenders (hooked to my whole-house A/V system for synched playback on multiple TVs - great during a Superbowl party) Amazon Firestick 4k and Nvidia Shield using the MiniClient Using CQC to control it all |
			#100
			Sorry, I wasn't clear; The halts are showing up when trying to stream to a remote (off-site) location with poor (<6Mbs DSL) from a server location with pretty good bandwidth (~11Mbs upload).
|  Similar Threads | ||||
| SageTV miniclient - transcoding? | dmelnyk | SageTV Clients Development | 1 | 10-02-2016 05:01 AM |
| SageTV & HDHomeRun PLUS w/ Transcoding h.264 | bigbill | Hardware Support | 12 | 06-03-2014 06:33 AM |
| SageTV 7 and h.264 transcoding | thegodfaza | SageTV Software | 1 | 11-25-2010 12:12 AM |
| Info on SageTV transcoding | MrFusion | SageTV Software | 4 | 11-09-2009 07:07 AM |
| SageTV Transcoding | ptaylor | SageTV Software | 0 | 02-17-2007 03:39 PM |
