				Switching OS from Win7 32bit to 64bit ... how to retain all Sage data?
			I am planning to upgrade Win7 from 32bit to 64bit, which means a full install.  I have Sage running now on the 32bit and I have read that I shouldn't have any problems with 64bit.  I assume I may have to re-install Sage since Java will be 64bit now.  However, I want to retain as much of my Sage environment as possible (i.e. Recordings, Favorites, etc, etc).  What files do I need to backup / restore (i.e. Sage.properties) to make this happen and is there any merging necessary?
	Thanks in advance.  |
			These worked for me.
			Sage.properties SageClient.properties *.autobackup Wiz.bin
	hp intel quad 2.8Ghz 16GB ram Win 7 pro 64bit hauppauge 1250 usb/serial connect 15TR storage recording directv TRYING  |
			Do not copy .properties files from one machine to another, or from one OS to another on the same machine.  They contain settings specific to your machine's device drivers and folder structure.
			V7 .properties files also contain information about installed plugins that will be incorrect if you drop them into a fresh install on a new machine or OS. This can interfere with your ability to install or uninstall plugins in the future. If you're doing a new installation of Sage, even on the same machine, keep your old Wiz.bin but configure everything else from scratch through the UI.
	-- Greg  |
			Thanks Greg.  I wondered if the properties files would change if I re-installed, so its a good thing I checked.   I take it the Wiz.bin file holds all the normal data like Recording information, Favorites information, etc.
			Yes, Wiz.bin has your viewing history, favorites, and the location of all the recordings.  What you should do is get everything re-installed (tuners, import and recording directories, etc) and then switch out the new empty wiz.bin with your backed up version.  After that assuming recording directories and import directories are in the same spot you should be back where you started.
			btl.
	PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient  |
 Also, I have firewire channel changing software installed in the common directory I think - can that just stay where it is, aka will Sage recognize it when rebuilding?  |
| converting from win7 32bit to 2008 64bit | rdefino | SageTV Beta Test Software | 6 | 09-28-2010 02:26 PM |
| New Build with Sage7 - Win7 or no? 64bit or 32bit? | ThePaladinTech | SageTV Beta Test Software | 6 | 05-22-2010 09:01 AM |
| Windows 7 64bit or WHS 32bit? | nebulink | General Discussion | 20 | 03-08-2010 12:40 AM |
| 64bit processors with 32bit OS Question | Stuntman | Hardware Support | 8 | 09-08-2006 10:12 AM |
| Renaming Server, any way to retain existing video recording with Sage data? | Crowdx42 | SageTV Software | 6 | 09-08-2004 10:13 AM |
