Hardware Support Discussions related to using various hardware setups with SageTV products. Anything relating to capture cards, remotes, infrared receivers/transmitters, system compatibility or other hardware related problems or suggestions should be posted here. |
USB-UIRT double entry
When using the hauppauge 45 remote with the USB-UIRT I have to double all commands (example hit Play Play to Play, Press Up/UP to scroll up, volume twice up or down) and so on.
Anyone have any suggestions? Thanks ![]() ![]() ![]() ![]() ![]()
Windows 7 Ultimate / SageTV server/client 7 / ZOTAC GeForce 9300 4 gig memory / Hauppauge 2250 / USB-UIRT / DirecTV D12-100 / 2-500 gig SATA drives / wireless keyboard. Last edited by mclement60; 02-16-2011 at 08:15 PM. Reason: Title |
The Hauppauge remote uses a toggle type of IR code, so each button emits two different IR codes when pressed repeatedly -- you have to learn each button twice with the USB-UIRT w/o pressing any other remote button in between.
SageTV Open Source v9 is available. - Read the SageTV FAQ. Older PDF User's Guides mostly still apply: SageTV V7.0 & SageTV Studio v7.1. - Hauppauge remote help: 1) Basics/Extending it 2) Replace it 3) Use it w/o needing focus - HD Extenders: A) FAQs B) URC MX-700 remote setup Note: This is a users' forum; see the Rules. For official tech support fill out a Support Request. |
Tags |
commands, double, usb-uirt |
IR USB Blaster Other Than USB-UIRT? Driving Me Nuts-Can't Remember | Savage1701 | Hardware Support | 7 | 01-21-2011 06:58 AM |
USB-UIRT | pknowles | Hardware Support | 3 | 09-01-2009 07:42 PM |
double transmit UIRT | jepalmer1391 | Hardware Support | 4 | 12-13-2008 12:44 PM |
USB UIRT is sending double digit of the number | mistergq | Hardware Support | 4 | 08-29-2008 08:04 PM |
USB-UIRT Remote Commands Executed Double | RAlfieri | SageTV Beta Test Software | 11 | 12-18-2006 04:59 PM |
