SageTV v7 Customizations This forums is for discussing and sharing user-created modifications for the SageTV version 7 application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss plugins for SageTV version 7 and newer. |
Web Feed Encoder 0.9.7
I have made a pre-release available via the plugin manager. The plugin is marked as beta so proceed with caution! The web feed encoder has been turned into a V7 plugin thus:
Its probably best to discuss issues related to the V7 plugin start/stop/install/uninstall here and but more general issues here http://forums.sage.tv/forums/showthread.php?t=40637. Enjoy. Michael |
Thanks! This looks very nice!
Does it require a reload after install? I noticed there wasn't an option for this and when I went to install the remote part of this, Sage shutdown. Not sure what happened but I restarted then installed the remote part and it then installed OK. Not sure if you need the option to restart Sage after the install or if I just had a glitch ![]() I added a couple channels and they show up in the Guide but I'm getting "No Signal" on both. BUT, I haven't read any instructions yet or really had a chance to look at the Configuration part of this so it is probably just something I am doing wrong. I'll do some more reading about just how this works and if I have any trouble I'll post back. Thanks! This looks like it'll be pretty darn nice! |
Michael,
Not at home to try it right now, but are there any known issues (or do you have instructions) about uninstalling the previous version, if it was manually installed in Sagev7? With all the changes for v7, is a complete uninstall recommended, and are there some folders/files that would need to be manually deleted? Thanks!
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. |
Hmm. Same here...
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, 36TB Synology 1019+ for DVD/Bluray Rips, Music, Home Movies, etc., SageTV Server 64 Bit Ver 9.2.6.976, HDPVR x 2, Bell TV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver Clients: PC Client x 2, HD-300 x 2 (1 Using Netgear MoCA Coax Bridges), SageTV Miniclient on NVidia Shield x 3 |
Michael,
Don't see an option in the plugin config to start your WFE channels higher than 900. Does this have to be changed manually? My Bell (Expressvu) receiver has channels already in the 900 range. Tnx! -S
So you should install the server plugin. The remote config is only needed if your server is headless. The server install should have restarted the server. If you can see your two tuners in config - setup video source and they have a lineup of WebFeedEncoder than all should be well. On the no signals - there is lots that can go wrong here. Can you send me SageTV/webfeedencoder/logs/encoder.log pls for starters. The SageTV/webfeedencoder/channels/<callsign>.props file will help me to. Michael |
1. just upgrade to 0.9.7 using the previous pattern of running the installer and ignore the plugin manager. OR 2a. Take a backup of the 0.9.6 webfeedencoder directory 2b. Run the 0.9.6 or 0.9.7 installer and choose uninstall 2c. Use the V7 plugin manager to install webfeedencoder 0.9.7 2d. In the config screen down the bottom is a button where you can select the backup dir of 0.9.6 that you created. Your previous config will be imported. The SageTV server will restart. When it comes back your channels should return. You may posisbly need to use the config tool to repost the lineup and EPG after this. Michael |
I'll do that and post another version. If you already have an 0.9.6 installation see the post above about upgrade. This would also import your previous setting of where the range of channels should start as well as all existing channels. Michael |
Also, does this plugin install VLC? I got to looking and I didn't see it installed on my computer so I downloaded and installed VLC. Still got the "No Signal" so I uninstalled the plugin and reinstalled. Same results. One thing to note is that the first time I go into the Config Tool I get a Java error and the Config Tool closes. I then reopen it and it appears to be working at that point... tells me the encoder is running and Sage is running. I add a couple channels and test them but not really sure what I'm supposed to be seeing here. I do get the EPG grab but testing reception for, say, NASATV gives me the following: Code:
Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 Request recording NASATV C:\Program Files\SageTV\SageTV\webfeedencoder\tmp\NASATV_test.mpg Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 ********** Starting recording NASATV C:\Program Files\SageTV\SageTV\webfeedencoder\tmp\NASATV_test.mpg Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 Command: Vlc "VLC" "%url%" --sout="#transcode{vcodec=mp2v,vb=%video.bitrate%,fps=%video.fps%,scale=%video.scale%,width=%video.width%,height=%video.height%,acodec=mpga,ab=%audio.bitrate%,channels=%audio.channels%}:duplicate{dst=std{access=file,mux=%video.mux%,dst='%recording%'}}" --sout-transcode-audio-sync -I rc --rc-host=localhost:%streamAsVideoCommandPort% --rc-quiet %vlclogging% Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 UNC fix keeping recording file as C:\Program Files\SageTV\SageTV\webfeedencoder\tmp\NASATV_test.mpg Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 Failed to process command Vlc "VLC" "%url%" --sout="#transcode{vcodec=mp2v,vb=%video.bitrate%,fps=%video.fps%,scale=%video.scale%,width=%video.width%,height=%video.height%,acodec=mpga,ab=%audio.bitrate%,channels=%audio.channels%}:duplicate{dst=std{access=file,mux=%video.mux%,dst='%recording%'}}" --sout-transcode-audio-sync -I rc --rc-host=localhost:%streamAsVideoCommandPort% --rc-quiet %vlclogging% java.lang.NumberFormatException: For input string: "" at java.lang.NumberFormatException.forInputString(Unknown Source) at java.lang.Integer.parseInt(Unknown Source) at java.lang.Integer.parseInt(Unknown Source) at uk.co.mdjcox.configdb.ConfigDb.getStreamAsVideoPort(ConfigDb.java:629) at uk.co.mdjcox.webfeedencoder.RecordingThread.replaceTokens(RecordingThread.java:356) at uk.co.mdjcox.webfeedencoder.RecordingThread.processCommand(RecordingThread.java:519) at uk.co.mdjcox.webfeedencoder.RecordingThread.startRecording(RecordingThread.java:174) at uk.co.mdjcox.webfeedencoder.RecordingThread.run(RecordingThread.java:77) Jul 28, 2010 10:48:56 AM: WebFeedEncoder-0 Recording started I uploaded the props files. Just delete the .txt off the end. I tried attaching the log file but it says it is too big? Anyway, here is the contents of that file... Code:
# ====================================================================== # Channel properties: NASATV # ====================================================================== audio.bitrate=128 audio.channels=2 callsign=NASATV desc=NASA TV id=nasa-tv lang= name=NASA TV subtitle.color=16777215 subtitle.position=8 subtitle.size=30 subtitle.text=\ type=allinternettv url=http\://www.youtube.com/NASATelevision url2= url2type= video.ar=16\:9 video.bitrate=800 video.fps=30 video.height=576 video.mux=ts video.scale=1 video.width=720 grabber.timezone=Local # ====================================================================== # End of channel properties: NASATV # ====================================================================== |
scanner95 is having similar issues on the other thread.
Will investigate and get back to you. Incidently - I've have just noticed there is a new version of VLC 1.1. In the usual style of VLC nothing that worked before works now in the same way. I would download and install 1.0.5 (it will remove the other version for you) Michael |
![]() I gotta step away from the computer but if you have any other ideas for me to try, I'll give it a shot when I get back. Thanks for this great plugin! |
Hmm... well that was interesting. I put Sage in a window, tuned to WesternTV and just let it set there for a few minutes while I did something else and it started to play with the audio and video fine. It took a LONG time with the circle spinning away in the center but I am getting video as well as audio now. Just tried the same thing with NASATV and I'm getting a picture (no audio) and the picture froze a few seconds in but this is a start
Something to try which takes SageTV out of the equation... Use the config tool to test a channel if it plays fine then its SageTV being a PITA. If there are still problems then if you want to take webfeedencoder and SageTV out of the equation you can just run up VLC. Choose file->open->network and paste in the tuning URL. If there are still problems then its the remote server, the network, or some resource constraint on you box. I've just noticed the channel has a different tuning URL on my home box: http://www.nasa.gov/55644main_NASATV_Windows.asx You could try that for size. What version of VLC are you now using by the way? Michael |
Hey Michael! Still not at my computer so can't try what you suggested just yet but...
I "downgraded" to VLC version 1.0.5 before I added the configuration stuff you mentioned in the other thread. I'll try version 1.1 again and see if it works. Also, I noticed when I uninstalled and then re-installed this plugin that about 5 or 10 seconds after the install was complete and I hit the done/OK button indicating that installation was complete, Sage restarted. Just an FYI that this is exactly what happened before and the reason I thought it "crashed" was because in the other plugins that I've installed which required a complete restart of Sage, a menu item came up indicating that a restart of Sage was required and asked if I wanted to restart now or later. With yours, it just restarts with no indication that Sage is just going to close... that's why I thought something went wrong ![]() I do have RoadRunner Lightning and get, on good sites, over 1 megabyte per second download speeds. I'll try some of the testing outside of Sage that you mention. Thanks much again for the work you put into this plugin. I've got some IP cameras I'm excited to try out too once I get a few moments ![]() |
Similar Java exception that someone else posted here in my encoder log... Using VLAN 1.02. No problems playing the parrot URL through VLAN itself... Hope this helps. -S
D'oh! I just read:
http://forums.sagetv.com/forums/show...849#post438849 Added as suggested. It gets me further. Now when I try to tune the parrot cam, I get an error saying: "Windows cannot find "C:\Program Files\VideoLAN\VLC\VLC.exe Which makes sense, as those of us using 64 bit, X86 apps end up in: C:\Program Files (x86)\.... Changed it in the encoder.props However I'm back to No Signal again.... :-( No java exceptions in encoder log tho now...
I just ran a speed test from this computer and am getting 36,211kbps so I don't see my problem being a slow internet connection. Quote:
Thanks! |
Can you post the encoder.log please. Also when you try and tune the channel open up windows task manager. You should see a java.exe with encoder.jar in the command line You should see a vlc.exe session quoting a vlc-conf file <callsign>.conf. Does the vlc.exe session memory use grow - does it look like its busy. If memory stays the same and it doesn't seem to use CPU then it has probably crashed. This usually turns out to be a windows permissioning problem. Michael |
Utility: Web Radio and TV Encoder | michaeldjcox | SageTV Customizations | 858 | 02-27-2021 10:26 PM |
Plugin: SageTV Web Interface V2 for Jetty | jreichen | SageTV Customizations | 256 | 02-09-2014 08:05 AM |
Web Radio and TV encoder Announcement Thread | michaeldjcox | Customization Announcements | 6 | 12-10-2010 03:56 PM |
SageTV and web radio | michaeldjcox | SageTV Customizations | 3 | 12-01-2008 11:09 AM |
STV Import: Web Radio Plugin for SageMC v1.1b 7/31/06 | Morgan111 | SageMC Custom Interface | 90 | 03-24-2008 08:17 AM |
