Old 08-01-2009, 08:47 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Arrow STV Import: OSD Signal Meter
OSD Signal Meter is an import for the default STV that places a small bar-style signal meter to the right of the On Screen Display. It is meant to be used as a tool to help debug signal dropout issues.
To see how strong your signal is select "Watch LiveTV" and the bar will appear to the right of the bottom OSD panel.
Known limitation: If you are watching something live and press the "pause" button, the signal meter will be out of sync with what you are seeing on the display.
Helpful hint: If you want the OSD to remain on the screen you can adjust the inactivity timeout (or even eliminate it) by going to Setup->Detailed Setup->Customize and changing the settings for "Inactivity Timeout and OSD Hide".
To install save the .stvi file to ../SageTV/SageTV/STVs/SageTV3 directory and import it.
Download here: http://forums.sagetv.com/forums/down...do=file&id=329
Sage Server: 8th gen Intel based system w/32GB RAM running Ubuntu Linux, HDHomeRun Prime with cable card for recording. Runs headless. Accessed via RD when necessary. Four HD-300 Extenders.
STV Import: OSD Elapsed Playtime Display gexi SageTV Customizations 3 11-13-2010 11:02 AM
STV Import: Display Output Info on OSD for Default STV razrsharpe SageTV Customizations 18 05-21-2010 08:15 PM
STV Import: OSD autohide override koelec SageTV Customizations 11 06-19-2008 09:14 AM
STV Import: SageMC Enhancements (incuding Import Folder Fix in 6.2.x) twieder SageMC Custom Interface 59 05-06-2008 01:42 PM
Feature Request - CPU meter in OSD Humanzee SageTV Customizations 11 11-19-2004 09:57 PM
