| SageTV Media Extender Discussion related to any SageTV Media Extender used directly by SageTV. Questions, issues, problems, suggestions, etc. relating to a SageTV supported media extender should be posted here. Use the SageTV HD Theater - Media Player forum for issues related to using an HD Theater while not connected to a SageTV server. |
Default Aspect Ratio for an extender
Still can't seem to find a way to make my default aspect ratio of "Fill" stick for any of my extenders.. no matter what I pick in the settings, the video seems to always play as 'source'...
Is there some way to force the extenders to fill non HD content?? Thanks! |
I seem to recall that, but couldn't find anything obvious in the properties file..
You probably have to add it. Check the similar threads at the bottom of the page.
default_advanced_aspect_ratio=Fill
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
Another question.. isn't that what selecting the AR in the setup is supposed to do? Every time I change that, it seems to revert back.. Now.. to figure out how to determine which device is attached to which property.. |
I'm trying to do the exact same thing... but it doesn't seem to be working. I put default_advanced_aspect_ratio=Fill in the properties file and it still doesn't "stick". I have also tried: default_aspect_ratio=Fill and default_aspect_ratio_mode=Fill But those don't work either... anyone get this to work?
It needs to be set in the clients\<macaddress>.properties file, not the sage.properties, or sageclient.properties files.
Understood. That is what I did.
And did you also shut down SageTV service or SageTV running on the server? And shut down the extender? And then edit and save the file?
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. |
Yes.
Is there a solution to this? I'm using SageTV 6.3.5 and the HD-100 with firmware downloaded yesterday (3/5/08) and I absolutely cannot get it to hold the AR to Fill. If I turn the unit off and back on, it goes to Source every time.
It was fixed in the core, I think in 6.3.8.
This is why I love these forums....Been annoyed by this the last two nights. Decided it was time to get it figured out and voila, here is my answer. Thanks everyone!
Sage Server: AMD Athlon II 630, Asrock 785G motherboard, 3GB of RAM, 500GB OS HD in RAID 1 and 2 - 750GB Recording Drives, HDHomerun, Avermedia HD Duet & 2-HDPVRs, and 9.0TB storage in RAID 5 via Dell Perc 5i for DVD storage Source: Clear QAM and OTA for locals, 2-DishNetwork VIP211's Clients: 2 Sage HD300's, 2 Sage HD200's, 2 Sage HD100's, 1 MediaMVP, and 1 Placeshifter |
Heres the response I got from Sage support:
You have to use the current beta. http://www.sagetv.com/betadownload.html Then close SageTV and service and look for this line in your Sage.properties file in the SageTV folder default_advanced_aspect_ratio You can set the default one there. Thanks, George Oms SageTV, LLC |
I run a headless server and only use the Extenders (3HD, 1 MVP).. but would love the aspect ratio to go to fill whenever that ratio isn't the native recording... just like to use the entire screen on the TV. Still haven't gotten this to work. Sure wish it was as easy as choosing the default aspect ratio setting in settings..
Intel Q6600 Quad Core, 8GB RAM on Windows 7 Professional x64 |
This has worked for me without any problems ever since 6.3.8 or so. The default_advanced_aspect_ratio goes in the <macaddress>.properties file of each extender. Make sure the extender is not ON when you make the changes to this file!
ie - the path on my server to one of my HD extenders is C:\Program Files\SageTV\SageTV\clients\00085c53a288.properties btl.
If you put it in the sage.properties file, I believe each new extender you hook up will use it, client settings in the Sage.properties file are used as defaults when a new client configuration is created.
So you can set it in Sage.properties to affect all extenders that don't already have it set, or you can set it individually in each extender's properties file. If the property is not working for you, maybe you are using an older version of 6.3, so update to v6.3.10. - Andy
SageTV Open Source v9 is available. - Read the SageTV FAQ. Older PDF User's Guides mostly still apply: SageTV V7.0 & SageTV Studio v7.1. - Hauppauge remote help: 1) Basics/Extending it 2) Replace it 3) Use it w/o needing focus - HD Extenders: A) FAQs B) URC MX-700 remote setup Note: This is a users' forum; see the Rules. For official tech support fill out a Support Request. |
i've read all these...no luck....
Until i read the fine print........
I cut and paste to all extenders & main properties file. it helps to write "fill" not "full" 2 days it took me to learn to read & spell ![]() just thought i share my funny little story!
Luv Ya Sage!! Hanging On!! HD-100(x2), HD-200(x2), HD-300(x2), MVP(x2) ,HDHR-(original), HDHR-Dual, HDHR-Prime, SageDCT, Hauppauge HVR-1600 & 1800, Windows 7(64bit) Pentium Dual-Core E6300 2.8gHz, 4GB, Gigibit E-Net, Placeshifter(x2), Client (x1)... I've Tried all Media Centers, Sage Still The Best! Hmmmm, Google Fiber
| HD Extender Default aspect ratio setting in 6.3.6 not working | toricred | SageTV Beta Test Software | 9 | 01-25-2008 01:47 PM |
| source aspect ratio problem | jharterman | SageTV Software | 1 | 10-20-2007 07:42 PM |
| aspect ratio problems | rnewman | SageTV Software | 6 | 10-08-2007 07:56 PM |
| Aspect ratio stopped working in V4.1.4 | AMCooper63 | SageTV Beta Test Software | 3 | 01-31-2006 06:57 AM |
| Default aspect ratio | vuego | SageTV Software | 1 | 01-15-2005 03:28 PM |
