Old 01-12-2007, 10:21 PM
ditohead ditohead is offline
Where can I download previous versions of SageTV?
I had version 5 installed and thought I had upgrade rights to version 6. Turns out I did not as indicated when I entered my license key after installing version 6. Unfortunately I cannot find my version 5 installation file(s) now. Can someone please provide a link to download the latest version 5 download so I can reinstall it? None of the new features appeal to me, so I'm going to hold off on upgrading for now.
Thanks in advance!
Old 01-13-2007, 03:48 AM
Hades's Avatar
Hades Hades is offline
Sage 5.04 Link
http://forums.sagetv.com/forums/showthread.php?t=22303
Gives link to 5.04
Abit AN-AM2HD | AMD5000+ | 2048MB DDR2-800 | ATI-3650 | 3TB Storage | Sage 6.4.8/Meedio 1.41 | XP 32BIT | FireDTV S2 | WinTV-NOVA-S+ | USB-UIRT/MX-500 Remote | Antec Fusion Case | Zalman Reserator 1 V2 | 1GB NIC`s
Old 01-18-2007, 02:43 PM
david zero david zero is offline
I bought STV 4 a couple of years ago. Was happy with it. Tried Version 6 and decided to stick with version 4. Version 6 timed out and screwed up my video and Skype audio. After completely uninstalling it (had to use control panel since there is no "uninstall" icon from Sagetv) all returned to normal. Now I'm ready to return to version 4 which worked just fine thank you, but I can't find where I can download the latest version 4. Can someone direct me to the page. Thanks - Carl.
Old 01-18-2007, 03:21 PM
amg amg is offline
If I remember correctly, v4 was only beta. Check out the Beta Progress report thread for links to all the betas.
unRaid Server:Quad-Core Xenon, 20 GB Ram, openDCT/sageTV Dockers, HDHR,HDHR Prime
Network Encoder:Dell Inspiron 1000 Laptop, 512MB Ram, Windows XP, HDPVR
Old 01-18-2007, 05:11 PM
BobPhoenix BobPhoenix is offline
Actually it was version 3 that was only beta. But the version # was changed to 4 when Studio was included.
Old 01-18-2007, 11:45 PM
Menehune's Avatar
Menehune Menehune is offline
For version 4.1.14 Try:
Old 01-19-2007, 03:32 AM
astribli astribli is offline
Where can I get 6.0.18?
I want to do a test and see if 6.0.19 is causing stuttering and locks up on my machine.
Anyone have a link to where I can download 6.0.18, or maybe even slightly older versions too?
Old 01-19-2007, 11:07 AM
All you have to do is copy & paste the download link, then change the version number in that link.
Old 01-19-2007, 12:11 PM
Thanks !
Old 01-19-2007, 01:10 PM
jbarr's Avatar
jbarr jbarr is offline
What are the ramifications "downgrading" to a previous sub-version? For example, v6.0.15 was very stable for me, but now, v6.0.19 seems to stutter more, and I'm having Overlay issues (I know, I know, contact support.) Anyway, if I have v6.0.19 installed (that was upgraded from v6.0.15) and want to revert back to v6.0.15, would this be a problem? Or would this require a complete, uninstall and fresh re-install?
Oh, and to possibly complicate matters, when I upgraded from v6.0.15 to v6.0.19, I used the same STV that I was using with v6.0.15.
-Jim Barr
SageTVTips.com
HTPC: AMD ASUS M2N-E Socket AM2 Motherboard; Athlon 64 3200+ Orleans 2.0GHz; 2GB RAM; eVGA 256MB Geforce 7300LE; 1x40GB IDE HDD (OS), 2xSeagate Barracuda 320GB SATA HDD (Recordings); Antec Overture II Case; Windows XP Pro SP2; SageTV v6.5
STV: SageMC
Video sources: Currently, none. I'm using SageTV for Music, Photos, and Video playback.
Old 01-19-2007, 01:34 PM
Can't add much insight but I can tell you that I uninstalled 6.0.19 and installed 6.0.18, and it remembered all my settings. Now, as far is does it fix the stuttering/lock up issues, time will tell.
Interesting about 6.0.15 being stable for you. Maybe I'll try that too. Mine is a new setup so don't have much to lose if something goes wrong. Tivo is hooked back up again so at least the wife and I have something reliable.
Old 01-20-2007, 01:30 PM
Oats Oats is offline
Where can I download version 5?
Since the upgrade to 6 is not free I was suprised I couldn't find a link on the website to download version 5. Maybe I am just missing it, but could somebody point me to where I can get it?
Old 01-20-2007, 02:04 PM
mrcandu's Avatar
mrcandu mrcandu is offline
http://www.sagetv.com/postDL.php?tmp...5_0_4Setup.exe
Server/Client: 1.6GHz Intel Atom 330 | 2048MB DDR2 | Iomega 2TB eSata Hard Drive | Nvidia Ion | HDHomeRun DVB-T2 | Hauppauge NOVA-TD Stick x 2| Windows 10 | SageTV v9.0.12 | Java 1.7.0_79
Clients: HD100 | HD200 | HD300 | MI Box
Old 02-02-2007, 04:52 PM
henk99 henk99 is offline
Old Version, where do i find it?
Hi
I just did a clean install of windows XP on my system after having some troubles. Before i started i made a backup of the complete sagetv dir. Now i need to install sagetv first before i can get the old stuff back, but i don't know where to find the older v5 setup file. I'm not a v6 user yet, so i'd like to have the previous version.
Cheers,
Henk
XP Pro SP2, SageTV v5.02.90, Athlon XP 3000+ (FSB 333 MHz), 2GB DDR RAM PC3200, 36 GB Western Digital Raptor, 200 GB Western Digital harddrive, Asus Radeon 9600 XTR, Plextor PX-708 8x DVD-/+RW, Pioneer 120S 48x CD-RW, PVR 150 MCE (2). Hauppauge MVP.
Old 02-02-2007, 05:17 PM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
I think this is the last release of v5. If not, then just substitute the correct release number.
Aloha,
Mike
"Everything doesn't exist. I'm thirsty." ...later... "No, it's real!!! I'm full."
- Nikolaus (4yrs old)
Old 02-11-2007, 06:56 AM
Beaker's Avatar
Beaker Beaker is offline
Download Old Version?
Where can I get V.4? I need to reinstall, but lost the installer.
* merged; see above *
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 02-24-2007, 11:57 PM
InTheFlow InTheFlow is offline
Can you still download Version 5?
If so, where? Sage's download web page points only to version 6.
Thanks.
* merged *
Old 02-25-2007, 07:43 AM
Thanks.
* merged *
Read the third post up from this or the second post up from yours.
Old 02-26-2007, 12:04 AM
Well, that is a bit embarrassing. I guess I just wasn't paying attention.
Old 02-27-2007, 10:51 PM
reboot_this's Avatar
reboot_this reboot_this is offline
I tried changing the version number to download v6.0.12 Beta but it just keeps redirecting me to a "missing file" page, here's what I typed in:
http://download.sage.tv/SageTVClient...2BetaSetup.exe
and
http://download.sage.tv/SageTVClient_V6_0_12Setup.exe
any suggestions?
HTPC HW: Gigabyte GA-EP45-UD3P, Intel Q9400, 2GB Corsair RAM, PNY Nvidia GT210 vid card, 3 HVR2250s, 2 PVR250s, USB-UIRT (2 STBs), Internal FireWire/Dual IDE Converter (IFC-1)
HTPC SW: XP Pro/SP 2, SageTV v7.1.5.252 Beta, Java v1.6.0_10, PVR drivers v1.18.21.23257, HVR drivers 7.6.1.27118
HD100 Extender: 2 (server is just a server)
Future plans: 1 more HVR2250, 1 Ceton CC 4-way tuner, 10TB diskspace
Issues: 1 PVR250 not working, system board?
Tags
older version, previous version
