| SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here. |
I'm currently running 6.0.15 with a Nova-T (9003), on a test box. I'm experiencing an issue when I flick through the channels, where certain channels appear as "no video". If I scan through the channels, and make a note of which ones are not working, restart Sage, the channels appear to work. Typically Sky Three (ch11) and UKTV History (ch12) appear to be a problem. But following a Sage restart (not system restart), generally they work.
I'm in the UK, using freeview from Crystal Palace, and I've enclosed my frq file. The frq file was generated from within Sage, but I've massaged the channel numbers to match the Freeview lineup. My next step is to backup my Sage install, and re-install from scratch and re-test. Before I do this, has anyone else experienced this? Or got any recommendations or advise? Thanks, Steve
Sage v6.34RC2, SageMC, Cinergy 2400i, USB-UIRT, CPU:Athlon 3000+, RAM:1GB, Storage:2x300GB WD (RAID1), OS:XP. (JRE 1.6; NielM's Multi Line-up) |
I had this problem testing using version 6.0.14,
I went back to version 6.0.13 and the problem went away. I though 6.0.15 had fixed this "no signal" problem JJ |
I'm on 6.0.15 too with a Black Gold tuner and have the same issue... some channels disappear, but come back on a restart.
Also, seems to hang on some channels with the OSD not fading out after the timeout. Just stays with a black screen and the OSD. I can hit home and the system still runs, but those channels appear dead. SageTv restart fixes it. |
Same problem exists with DVB-S. Submit a bug report and include logs along with a summary of what you did i.e. Tuned x which failed, then tuned Y which was ok...
Although I don't use DVB-T, I have the same problem with DVB-C (FireDTV). Some channels sometimes give a "no signal" message. Some channels have this problem more than other ones. Zapping channels or restarting Sage usually helps, but it doesn't give me any confidence that unsupervised timed recordings are ok.
The application that came with FireDTV (MyTheatre) always works. So it is not a problem with the FireDTV BDA drivers, I assume. I tried three different solutions: 1-SBDArecorder 2-bda interface included in 6.0.15 3-MyTheatre DVB Network Encoder Plugin and all show the same problem of "no signal". Solution 3 gives the best results. I submitted a bug report for 6.0.14 just before the release of 6.0.15. No reply though.... |
I am now having this problem with 6.0.19. This is the first version of 6 I have tried. I will post a bug report.
I have the same DVB-T problem with 6.0.19. At the same time, I have similar problem with my MPEG 2 captured card through s-video, which is a YUAN MPG600.
I had a similar problem when I first installed 6.0.17 (which I am still using). A selection of channels would not tune. They would just display the "No Signal" message.
If I rebooted a slightly different selection of channels would not tune. I tried rounding freqs down and up but there did not seem to be any logic behind it. I found that if left the channel on for about 5 mins (maybe longer) the channel would eventually tune. Next time I tuned the channel "No Signal" again. After a few days the tuning just seemed to stick and all my channels now tune no problem. I haven't upgraded to .18 yet tho edit: wrong version numbers
Server Sage 9||Silverstone GD09||Intel Core i5 6400||8GB DDR4||Intel integrated graphics||250GB SSD System disk||2TB recording disk||2TB media disk||1 TBS 6205 DVB-t2 quad tunrer||Schedules Direct EPG Last edited by pschweig; 01-02-2007 at 07:07 AM. |
I had similar issues, even with V5.
I have however found that if it is a case of leaving it on for a few minutes and then it tunes then this is purely related to the signal and the sensitivity of the cards tuners. I found that during the summer when its warm and humid the signal is worse. When its cold and dry the signal is better and the channels tune faster. To overcome this I installed an antena signal amplifier and adjust its gain up or down as required.
Windows 10 64bit - Server: C2D, 6Gb RAM, 1xSamsung 840 Pro 128Gb, Seagate Archive HD 8TB - 2 x WD Green 1TB HDs for Recordings, PVR-USB2,Cinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2 3 x HD300s |
I am also seeing this problem with 6.0.19 with a hauppauge nova-t usb2, the thing is i don't think it's a weak signal problem as a restart of sage and the channels tune straight away, although as described a different set of channels won't tune, again a restart fixes them. I am currently having to check that channels are tuning before recording which is not something that is always possible, I have submitted a bug report .
Seeing as again Sage seems to have "settled down" and is tuning solidly again I think that rules out the new aerial/position. I'm moving to .18 this afternoon - if I go through the same "No Signal" rigmarol I'll report it to support. Maybe Sage goes through a training period where it locks on to the strongest signal Pure guesswork on my part clearly but I'm sure Qian has the answers ![]() edit: wrong version number
Server Sage 9||Silverstone GD09||Intel Core i5 6400||8GB DDR4||Intel integrated graphics||250GB SSD System disk||2TB recording disk||2TB media disk||1 TBS 6205 DVB-t2 quad tunrer||Schedules Direct EPG Last edited by pschweig; 01-02-2007 at 06:55 AM. |
The "No Signal" message has returned when I installed .18.
Can't test all channels because some start broadcasting at 7pm so I will check again later. As before a selection of channels give "No Signal". A stop and start of the sagetv service results in a slightly different selection of channels not tuning. I have raised a bug with support
Server Sage 9||Silverstone GD09||Intel Core i5 6400||8GB DDR4||Intel integrated graphics||250GB SSD System disk||2TB recording disk||2TB media disk||1 TBS 6205 DVB-t2 quad tunrer||Schedules Direct EPG |
just noticed that sage sneaked out 6.0.19 without me noticing.
I have upgraded and I am seeing the same problem with .19 as well
Hi,
I have the same problem with v6.0.19 and a WinTV Nova-T USB2. Bug report submitted so hopefully it will be fixed soon. Cheers, Chris. |
Yes..... same problem here too. I found this with v5.0.4 and v6.0.18 using my nova-t pci card. I have raised a bug with support also.
Is everyone seeing this problem using Service mode?
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.3, tvHeadEnd for recording back end, Emby Clients: 3 Nvidia Shields, 3 FireTV, 3 Win10 Pro PC Clients |
Yes I am using service mode.
No.... I am not using service mode.
Server/Client: 1.6GHz Intel Atom 330 | 2048MB DDR2 | Iomega 2TB eSata Hard Drive | Nvidia Ion | HDHomeRun DVB-T2 | Hauppauge NOVA-TD Stick x 2| Windows 10 | SageTV v9.0.12 | Java 1.7.0_79 Clients: HD100 | HD200 | HD300 | MI Box |
I've seen it with both. I've reverted to using SBDA Recorder for now.
