Go Back   SageTV Community > SageTV Products > SageTV Media Extender
SageTV Media Extender Discussion related to any SageTV Media Extender used directly by SageTV. Questions, issues, problems, suggestions, etc. relating to a SageTV supported media extender should be posted here. Use the SageTV HD Theater - Media Player forum for issues related to using an HD Theater while not connected to a SageTV server.
  #21
Old 10-30-2006, 08:36 AM
AtomicPenguin AtomicPenguin is offline
Send a message via MSN to AtomicPenguin
Wasn't running service mode on any of the systems, though I did try it once. There were no 3rd party firewalls installed on any of these systems and the Windows XP Firewall (which is sub-par at best) was also disabled.
Just to note when the MVP starts up with it's initialization screen (before the wired test), it says 'Rev 2.05' and though this is the wired unit it has both a wired and wireless MAC address label on its underside.
Old 10-30-2006, 02:49 PM
stevech stevech is offline
since the MVP boots and runs with Hauppauge's server software, this thread sounds like the other discussions: Sage's bootp server is too slow or otherwise incompatible with the MVP for some as yet undefined situations.
Old 10-31-2006, 08:29 AM
I received an e-mail from support yesterday afternoon saying that this is supposed to be fixed in the latest v6 beta so I'll give it a whirl this afternoon or later tonight. I'll try to be optimistic about it.
*EDIT*
Still nothing.....still not working with 6.0.13...
Old 12-14-2006, 07:47 AM
Thumbs up
I just wanted to post an update that I finally have the MediaMVP working on my setup with v5.x. My original suspicion of faulty hardware was dead on. I ended up contacting Hauppauge directly (vs continuing on with SageTV support) and they replaced my MVP under warranty.
I received the replacement unit yesterday (just over one week after sending my unit to them) and it works like a charm.
