SageTV Media Extender Discussion related to any SageTV Media Extender used directly by SageTV. Questions, issues, problems, suggestions, etc. relating to a SageTV supported media extender should be posted here. Use the SageTV HD Theater - Media Player forum for issues related to using an HD Theater while not connected to a SageTV server. |
Picture Quality in Sage Menus
I just received one of the new wireless MVPs. So far it has worked great. I do have a problem with PQ though not with watching recorded shows or live tv. It is the PQ of the Sage menus that is giving me problems. All the text on the menus has really bad ghosting of text. Anything that is highlight is virtually unreadable.
Has anyone else experienced similar issues? Is there any type of adjustments that can be made? My TV is an old Panasonic that is about 8 years old and I'm using the RCA connections. Maybe this is a good excuse to get one of them flat panel tvs ![]() |
are you using the stock STV? If not, I would try using that and see if the ghosting disapears. If it does-the problem would be that you installed one of the custom stv's in the wrong directory. If you are currently using the stock stv then this wouldn't apply I guess.
Juc
Server: Athlon 2000XP; 1GB Kingston Ram; 250GB Seagate; 160GB Seagate; 160GB Western Digital; Lite-on DVD player; Hauppauge Rosyln; Hauppauge PVR-150; ATI AIW 7500; Actisys 200L; running stock v5 .stv Client: MVP Extender running SageMC |
I'm using the stock STV. I haven't changed anything.
I have a wired MVP installed to a new Tube HDTV and I notice ghosting and also warping on the menus and OSD as well. I just learned to live with it. Is there a way to improve?
Server: Dual Tuner: PVR-150MCE/PVR-250MCE/SageTV v5.02/Asus Pundit-R 2.4GHZ/512MB DDR RAM/250 GB Maxtor HD (8MB Buffer) External Seagate 400GB HD via USB 2.0/Onboard ATI 9100 using SVIDEO TV-Out/Nvidia DVD decoder/Actisys 200L IR Blaster (Dish receiver) USBUIRT (DirectTV receiver)/Lite-On 4X DVD-R/RW/Windows XP Pro SP2/Adesso Mini IR Keyboard w/integrated mouse/Tivo "Peanut" Remote via USBUIRT/Dish Network Model 301/DirectTV subscriber/Webserver Plugin v2.8 |
Just to let you know.. my MVP has always used S-Video and I experience the ghosting/OSD warping. In fact, the ghosting is more prominent with S-Video when compared to RCA connections.. just from my own experience.
I'm surprised this is even an issue. What would be causing this? I'm running s-video to a HD 42" plasma and experience no ghosting or warping whatsoever. I've also temporarily hooked it up by comosite with the same results. Could it be the quality of the cable?
Monster Baby!!! Monster.... yes and still slight ghosting.
Just never thought to say anything about it untill this post ![]() I have 2 MVP's... both have the same quality on menus on all TV sets using all combos of cabling and RCA/S-VIDEO combinations. Quote:
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. |
Did you guys who don't see ghosting use the original MediaMVP software tools?
I remember the one and only time I used it, it let you change the sharpness of the MVP video output. Quote:
yes i did!! I remember setting something regarding the flicker amount or something like that. Not sure if it was sharpness though. It was back when I was using Matt's plugin but I do remember changing something during the initial setup...the info might be in Matt's old thread.
setting flicker control to HIGH helped somewhat...
Well, I am happy to report that S-Video has solved the ghosting for the most part. There is only slight ghosting now in menu items that have been highlited. Everything else is fine now. The display still doe not compare to any of my PCs and they all have LCD screens.
Menus look terrible on MVP
I too am seeing terrible ghosting on my menus.. perhaps even in the video, but that is harder for me to notice... the menus ghost even during the initial SAGETV boot up screens. I've tried this on two 16:9 LCD Tv's.. I've tried it with both a Monster THX S-video cable and a standard RCA cable.. the issue remains no matter what I do!
I am using a wireless MVP with stock STV.. Any idea what might be causing this? Very disappointing when the old MVP on a cheapie TV with standard RCA looks WAY better than my new LCD TV with S-Video... ![]() |
Part of the problem is caused by the font that Sage uses. On a computer monitor you can see that the font has a black outline below and to the right of each character and when highlited becomes a black letters with white. It looks fine on a hi-res monitor but really bad via s-video 480i. On my TV the fonts look oversharpened and too close together. Now if only there was an easy way to change the font...
Wally |
-MrD |
