Go Back   SageTV Community > SageTV BETA Release Products > SageTV Beta Test Software
SageTV Beta Test Software Discussion related to BETA Releases of the SageTV application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Beta Releases should be posted here.
View Poll Results: What's your result using the updated DirecTV Serial Control DLL?
DirecTV Serial Control worked for me before in SageTV and it still works with this new DLL 8 22.22%
DirecTV Serial Control did NOT work for me before in SageTV and it DOES work with this new DLL 5 13.89%
DirecTV Serial Control did NOT work for me before in SageTV and it does NOT work with this new DLL 3 8.33%
DirecTV Serial Control worked for me before in SageTV and it does NOT work with this new DLL 20 55.56%
Voters: 36. You may not vote on this poll
Old 05-08-2006, 06:03 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Question Updated DirecTV Serial Control - TRY ME!
We built an updated version of the DirecTV Serial Control DLL for SageTV and wanted to get feedback from all of you on it since there's a wide variety of DirecTV receivers out there and we can't test them all ourself.
So if you're using the DirecTV Serial Control in SageTV (or you used to use it and it didn't work); then please give this a try and post your result in the poll. Thanks!
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-09-2006, 08:29 AM
RedR's Avatar
RedR RedR is offline
Hate to ask, but is this (backward) 2.x SageTV compatable? And please no, "update its great, or you should be current" msgs.
Old 05-09-2006, 10:44 AM
Narflex's Avatar
Sage
I think this should be 2.2 compatible. I don't think that interface has changed in a long time.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-13-2006, 01:19 PM
snipeman's Avatar
snipeman snipeman is offline
Tried it
I stand corrected, the new one doesn't tune 400 or 500 series channels
I had to reload my old one
I have an RCA DRD485RG (one of the newer command sets)
Andy
Old 05-13-2006, 06:50 PM
dagar dagar is offline
Jeff anything new or different for those of us that have a functioning rev?
Old 05-14-2006, 02:44 PM
Narflex's Avatar
Sage
Nothing really new for functionality....it's just supposed to change the channel. But it should work on more receivers now (all I'd hope) without any registry edits or other modifications.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-14-2006, 02:58 PM
dshields's Avatar
dshields dshields is offline
Would you expect this to work on a Motorola DCT 2244? Do I need any plugins or anything additional, or is this all I need? Thanks
Wakecrash Wakecrash is offline
Much slower channel changes with the new dll
Old 05-14-2006, 05:52 PM
ToxMox's Avatar
ToxMox ToxMox is offline
Here is a little feature request. How about USB control of cable boxes with USB ports on them. My SA digital cable box has a USB port and when I plug a USB keyboard into it I can punch numbers on the keyboard to control channel changes.
Old 05-15-2006, 05:48 AM
JUC's Avatar
JUC JUC is offline
Does this work with the D10-300 boxes?
JUC
Server: Athlon 2000XP; 1GB Kingston Ram; 250GB Seagate; 160GB Seagate; 160GB Western Digital; Lite-on DVD player; Hauppauge Rosyln; Hauppauge PVR-150; ATI AIW 7500; Actisys 200L; running stock v5 .stv
Client: MVP Extender running SageMC
Old 05-15-2006, 07:38 AM
JUC
I think they want you to try it and tell THEM if it works.
Old 05-15-2006, 08:10 AM
JUC's Avatar
JUC JUC is offline
Better get myself a cable then!
Old 05-15-2006, 10:57 AM
Narflex's Avatar
Sage
This DLL should also work with USB-control of DirecTV receivers using a USB-serial converter. This we have tested already.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-15-2006, 11:22 AM
ToxMox's Avatar
I'm not sure if you were replying to my feature request. So could this work with a cable box that has a USB port on it too? I'll give it a shot but I believe I'll probably need a gender changer for the serial end of the USB-Serial adapter to plug into the serial port of the PC.
EDIT: After rereading your post are you saying to use the USB to serial the normal way for a computer that doesn't have serial ports?
Old 05-17-2006, 11:06 PM
Homebuilder Homebuilder is offline
DirecTV boxes, which ones?
A little off subject, but...
I am moving to a new house, looking at Dish and DirecTV. I have read that some of the newer DirecTV boxes will not work with serial tuning etc.
Is there a list of what boxes work with direcTV? Dish?
Thanks in advance.
Old 05-20-2006, 12:00 PM
Peanut-Butter Peanut-Butter is offline
Samsung SIR-TS360 does NOT work with it.
Why won't sage support this reciver? Here are the serial commands for it.
Off=2A6474764A0D0A
On=2A647476490D0A
0=2A647476300D0A
1=2A647476310D0A
2=2A647476320D0A
3=2A647476330D0A
4=2A647476340D0A
5=2A647476350D0A
6=2A647476360D0A
7=2A647476370D0A
8=2A647476380D0A
9=2A647476390D0A
ch+=2A6474763E0D0A
ch-=2A6474763D0D0A
Enter=2A647476480D0A
Old 05-21-2006, 03:04 PM
jchiso jchiso is offline
What has been changed in this command set? Will it send a hypen ("-") command for ATSC subchannels? Will it support multiple-input sources?
Old 05-22-2006, 11:44 AM
Narflex's Avatar
Sage
Peanut-Butter, please send an email to betatest at sagetv.com and we'll see what we can do get that integrated.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-28-2006, 10:52 PM
Hector Hector is offline
I am assuming this is the same .dll in 5.0.3
I had to swap back to the old library because this one keeps sending something that makes the guide pop up on the screen. Not sure if its just at reboot or at a channel change, etc.
This partucular D* box is an older one, Sony SAT B3, I think its a 2nd gen. Beforehand it was working perfectly. At the time I had some people drop by and I didn't have time to isolate the problem but LMK if I can provide more info.
peace . . .
PVR user since the late 1900's . . .
Old 06-06-2006, 08:39 AM
that_kid that_kid is offline
The new dll which I'm assuming is in the 5.04 release doesn't work for me. It almost works, when I change the channel I see the command get sent to the bo but there's no enter key following the input of the nubmers so the channel never changes. So I went back to 5.02 serial control dll and all is fine.
