  #101
Old 10-22-2009, 03:19 AM
Polypro Polypro is offline
At the risk of confusing things further...I was under the impression that you were trying to plug 1 USB to Serial adapter from the computer (serial port) to the DirecTV Receiver (USB) and were having issues communicating to the serial port. I'm suggesting that you stop trying to use your motherboards serial port and just use the USB ports (so they will be identifiable, like my pic). To do that, you'll either need 2 USB to Serial adapters with a Null Modem adapter to connect them, or a Serial to USB adapter and a Paterson Device.
P
Old 10-22-2009, 05:18 AM
Fencepost Fencepost is offline
P
you were correct, that is what I thought I could do from reading through all threads. I have now ordered another adapter cable and will but the null in the middle.
Thanks,
Roger
ASUS P5Q3 MB, Vista Ultimate 32 bit, 2.8 Dual core quad, Nvidia GForce 9800 512 mb DDR3, 4 GB DDR3 ram,
HDPVR 1212 E1
Old 10-22-2009, 02:37 PM
Beefcake550 Beefcake550 is offline
let us know how it goes when you get the additional adapter Roger.
Old 10-22-2009, 02:43 PM
will do... another question: Have you heard if Sagetv and HDPVR will work on Windows 7 Ultimate 64 bit?
ROger
HDPVR 1212 E1
Old 10-23-2009, 09:03 AM
no clue of actual evidence. but I have been using Win7 on my own machine and it works great with old XP drivers on other stuff like a scanner. SageTV works great on Win7 as I've installed it as server (for playing around - without HDPVR) and as a client.
Old 10-25-2009, 08:31 PM
Hello Brian,
Monoprice sent me a different adapter even though I ordered the same part number from the invoice a week ago. After playing with it for a few hours, I got it to work, I think. Still testing.
Thanks for everyone's ideas. I still don't know why 1 would not work like everyone else.
Roger
HDPVR 1212 E1
Old 10-26-2009, 07:35 AM
weel, with 2 adapters, you would be at least like me, and mine works! If you have trouble with Sage's serial control, you could try the EXETuner plugin. I use that, but only because when I did my install, sage's serial control didn't work on the new receivers. That, I I believe in "if it ain't broke, don't fix it, mantra.
Old 10-26-2009, 03:34 PM
my contract is up in Dec, so I guess I will deal with the new receivers then.....
Roger
HDPVR 1212 E1
Old 04-30-2011, 11:03 PM
mickdaly's Avatar
mickdaly mickdaly is offline
USB Serial Controls won't start under WHS 3.0
I've been using two monoprice setups (as recommended in this thread) to control 2 directv receivers for 18 months with very few problems.
Until recently (when my HP mediasmart server system drive crashed!), I was running under an old release of WHS.
Temporarily I switched to my desktop to keep Sagetv running, and the usb serial contols worked fine under Windows 7.
Having now replaced my HP system drive and upgraded to WHS 3.0, I cannot get the usb controls to start - seeing the dreaded Code 10 error in Device Manager.
I've tried numerous other prolific 2303 drivers, to no avail.
Switched back to my windows 7 desktop setup and all is well - but I need my server setup back!
Anyone have any ideas, or seen this problem?
Mick
HP Mediasmart EX-485 server with 4.5tb storage, running Sagetv 7.0.23; 2 Hauppauge HD-PVRs; 2 Directv Receivers (H20 and H21 channel changing by usb/serial/usb cables); 4 Sagetv HD-200s; 1 Sagetv HD-300; Carada Criterion 126" screen; Definitive Technology speakers (UIW RLS II x 3, UIW BP/A x 2, DI 5.5BPS x 2, IWSub 10/10), Pioneer KRP-500M Kuro plasma; Pioneer Elite SC-07 receiver; Panasonic TH-50PH9UK plasma; Sharp Aquos LC-C4067U LCD; Oppo BDP-83 Blu-Ray player.
Old 05-01-2011, 06:51 AM
Not sure what WHS 3.0 is but Windows Home Server 2011 is a 64 bit OS. I'm not sure what version of Windows 7 you're running. You'll need certified 64 bit drivers on WHS 2011.
Old 05-01-2011, 11:37 AM
SWKerr SWKerr is offline
I had a problem when I went from WHS to Win7-64. The USB to serial cords I purchased (from original post) when I started used the moss 7703 chip. I was able to download the driver from the following link.
http://www.moschip.com/mcs7703_downloads.php
The issue with the above driver is that it is not digitally signed. It will install but Win7-64 will disable it on the first reboot. I found a work around but it is a bit complicated. I suspect it will work with the new WHS if it is 64 bit.
Driver Signature Enforcement Overrider is a program that will digitally sign the driver and allow it to run on your system. Link below:
http://www.ngohq.com/home.php?page=dseo
Hope this helps.
DirecTV USB Control chstuart Hardware Support 45 02-17-2009 03:29 PM
Directv Serial Control And TV Translator (With A H20-100) asthepenguinfly Hardware Support 5 06-04-2008 01:32 PM
Serial control works on DirecTV H21 mrwolf Hardware Support 0 02-25-2008 04:52 PM
Updated DirecTV Serial Control - TRY ME! Narflex SageTV Beta Test Software 89 12-23-2007 04:07 AM
New DirecTV Serial Control on Linux Server for 6.0.15 BladeUtah SageTV Beta Test Software 1 11-27-2006 07:27 PM
