| SageMC Custom Interface This forums is for discussing the user-created SageMC custom interface for SageTV. |
This import shows the current output display resolution to the timebar. It is useful when using the HD extender or theater to see what it is outputting to the TV without going through the setup menus.
It has been tested on SageMC 6.3.8a and SageTV 6.5.4 beta. A properties value is created that controls the display of the output resolution. razrsharpe/resolution_on_timebar=trueThe default value is true. Set it to false to not display the output resolution. Link to download: http://forums.sage.tv/forums/downloa...do=file&id=291
System Setup: Server 2003 r2 32bit, SageTV 6.5.17 beta, SageMC 6.3.9 2x HDHR (OTA), 1x HD-PVR (Comcast), 1x SageClient (WinXP Test/Development), 1x HD200, 1x HD100 Check out TVExplorer ![]() |
I'm not using SageMC, just the default Sage Client interface. I had to change the .XML to .STVI to import it. This plugin does not work. Is it supposed to without SageMC?
Server: ASUS P7F-E, Intel Xeon x3440, 4GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 3TB HDDs, 2x Hauppauge PVR-250, HDHomeRun, WinXP, Sage 6.x.latest Client 1: HD200 on Sony KDS-55A3000 Client 2: HD200 on Hitachi 36SDX01S Others: Sage Client & Placeshifter |
Valnar: Yes. It requires SageMC.
razrsharpe: I just loaded the import onto one of my client machines and have found that it always displays the resolution of the display rather than the resolution of the recorded material. I guess this is by design and intended for use with an extender which I'm guessing will vary output resolution depending upon the source material. Any chance of an option to display the resolution of the source material rather than the current display resolution? Mick. |
Valnar: I use SageMC and assume since SageMC is a complete replacement for the default STV that it does not work in the default STV because the default STV and SageMC refer to the timebar differently. When I have a second I will look into creating one for the default STV too, it shouldn't be too difficult.
mickp:Yes the extender varies the output resolution with source material if you enable that option. I also noticed that it just displays the display resolution when I had it loaded onto a client (not really useful). You are correct that it is designed to be used with the extender. However, I have also wanted to display the file format/resolution too so I will look into adding this functionality.
mick. |
I updated the stvi to include the file format description on the timebar. You can configure it via .properties file options to display either just the video resolution and fps or the full media file description (container, AR, resolution, Audio tracks and format) or not at all. See the download description for the properties file options.
Download link: http://forums.sagetv.com/forums/down...do=file&id=291
This might also help those of us trying to get 24p to work on the extenders.
Server: ASUS P7F-E, Intel Xeon x3440, 4GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 3TB HDDs, 2x Hauppauge PVR-250, HDHomeRun, WinXP, Sage 6.x.latest Client 1: HD200 on Sony KDS-55A3000 Client 2: HD200 on Hitachi 36SDX01S Others: Sage Client & Placeshifter Last edited by valnar; 12-30-2008 at 08:35 AM. |
![]() It's very useful because when changing resolutions, most TVs don't show the resolution the signal locks at.
Server: C2D, 3Gb RAM, 1xSeagate LP 1.5TB Recording HD, 8TB Green HDs for Videos, PVR-250, PVR-USB2, 2xCinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2 HD200 connected to Projector, HD100 connected to 46" LCD TV, HD200 connected to 42" Plasma TV, Media MVP to 29" SDTV |
Thanks for the update razrsharpe. Works a treat.
Mick. |
Valnar, Lucas: I had a chance to create the import for the default STV this evening.
Download: http://forums.sagetv.com/forums/down...do=file&id=293 Forum Thread: http://forums.sagetv.com/forums/showthread.php?t=38229
Thanks razrsharpe!! Much appreciated. Will try.
Where exactly do you save this file to?
Getting Sager all the time... Displays: Panasonic 65" P65S2 & 50" PX77E plasma/4 LCDs, 4 HD200s Source: 2 HD-PVRs, Rogers Toronto SA 8300HD PVR, 4250HD firewire tuned, WHS, SageTV, Sonos 1xZP100 & 3xZP120 wireless audio, Gigabyte GA45-E45-UD3R mobo, 2.5 GHz Core 2 Duo E5200 (2MB L2), Nvidia GeForce 96400GT, 120GB OS drive, 1 & 1.5 TB WD Caviar Green, Mushkin 2GB DDR2 800 SDRAM, El Cheapo case, Corsair 520HX modular Power Supply. |
-You can save anywhere but the simplest thing to do would be to unzip the file to your STV directory (normally: C:\Program Files\SageTV\SageTV\STVs\SageTV3)
-Then in SageMC go to My menu -> Settings -> Import STVi (I am at work right now so i can't check it, but I think that is right). It is just like importing any other STVi (customization). In the explorer box that pops up navigate to the STVi(.xml) and click OK.
System Setup: Server 2003 r2 32bit, SageTV 6.5.17 beta, SageMC 6.3.9 2x HDHR (OTA), 1x HD-PVR (Comcast), 1x SageClient (WinXP Test/Development), 1x HD200, 1x HD100 Check out TVExplorer ![]() Last edited by razrsharpe; 03-06-2009 at 06:26 AM. |
Is there any way to increase the size of the text font? I find it's too small to read at a normal viewing distance.
razrsharpe/timebar/font_size_factor=0.5 scaling factor for the font size from the base ui font size, default 0.5Setting it to a value of 1.0 will make it the same size as the timebar text. Remember to shutdown the client (or if using an extender stop the sage service) before modifying the property item.
Thanks. I am using Windows XP Pro and found sage.properties in c:\programs\sagetv\sagetv and modified it with notepad and saved it as sage.properties and that did the trick!
Excellent, glad it worked for you
The only problem is it appeared to show the proper resolution for a few shows (1920x1080@60) but then it switched to a lower resolution for (720xsomething I think) for another channel, which was correct, but then it got stuck on that resolution and showed it for every channel including the HD ones.
I am using it on an HD200.
| Thread Tools | Search this Thread |
| Display Modes | |
| STV Import: Comskip Playback for Default STV (v1.5.4 30/August/2008 for SageTV 5/6) | JREkiwi | SageTV Customizations | 588 | 08-13-2010 05:02 AM |
| STV Import: Slim Player for SageMC (for SageTV 6.3+) | Morgan111 | SageMC Custom Interface | 326 | 07-28-2010 06:54 AM |
| STV Import: Closed Caption Playback (v1.2.2 28/February/2008) | JREkiwi | SageTV Customizations | 472 | 01-20-2010 12:58 PM |
| SageTV V6.4.7 Release Candidate is Here! | Narflex | SageTV Beta Test Software | 2 | 08-12-2008 01:11 PM |
| STV Import: Multispeed Continuous FF/REW Import for SageMC | MeInMaui | SageMC Custom Interface | 20 | 12-16-2007 03:27 AM |
